Question about Microwave Ovens
Delonghi esam3300 problems
Hi there, first problem i was having with the machine was with the grinder, it was making the noise of grinding the beans but only a partial portion of the beans were getting grinded ( something like the grinder was still working but the beans were not going down ). Secondly, after the beans were grinded and the machine made the cake and made the coffee, not enough coffee was coming down ( it stopped pouring the coffee 1/2 way through the process) and the cake was wet like the water didn't go through and stopped up there where the cake is made
4 Suggested Answers
  • 8909 Answers
SOURCE: I need to replace the
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, and Installation Instructions as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Dec 30, 2010
Testimonial: "Thank you"
  • 10865 Answers
SOURCE: I have a deLonghi Magnifica
Hello scuzz. I recommend calling Delonghi directly: Contact Center
1-877-882-8604 Monday - Friday
8am - 8pm EST
They will tell you how to send it in for a repair and whether or not it is under warranty. Joe
Thanks for choosing Fixya!
Posted on Mar 06, 2011
  • 11800 Answers
SOURCE: Coffee is not coming through
The water valve has failed - the internal shaft that moves the flap was sheered off. The valve would have to be replaced by a dealer or certified repair shop - they are the only ones with access to replacement parts.
It will be expensive so ask an estimate before accepting the repair - it might be cheaper just to sell this one for parts and get a new one.
Posted on Aug 21, 2011
Microwave making noise all the time if plugged in & door shut
Sounds like a bad control board. Change it or buy another unit.
Jan 21, 2013 | DeLonghi Microwave Ovens
Delonghi ac925efy working but making noise all the time
This indicates a triac switching semiconductor problem, the triac is a switching device that allows the microwave oven to run on different power settings, if the defrost cycle is running on a higher power level it is most likely the semiconductor, but the possibility remains that the keypad control board may be the issue.
Apr 14, 2012 | DeLonghi Microwave Ovens
Grinder appears to be grinding, but not ground coffee ends up in the basket. Metal door underneath the grinder is closed.
Empty grinder and chek nothing is stucking to the opening plate If not then replace the solenoid that open the shuter from where the coffee go to grinding chamber Thanks Please rate my work
Sep 06, 2011 | Microwave Ovens
I need to replace the top that goes over the coffee bean holder on my Capresso 451 coffee machine. This is the old machine that grinds the beans and then makes the coffee. Where can I find this part
I hope this helps.
Dec 30, 2010 | Microwave Ovens
My DeLonghi Magnifica S ECAM23210 coffee machine is leaking water from the back.
I received the exact same machine for Christmas yesterday and had the exact same problem! I took it back to Williams Sonoma today and exchanged it for another one and I just started it up and have the SAME problem! Water comes out the bottom onto the counter - never even makes it up through the machine. This must be a batch of lemons - I guess I'll call Delonghi tomorrow.
Dec 25, 2010 | DeLonghi Microwave Ovens
After grinding coffee,can you submerse in water to clean
No!!! You can clean the cup that the coffee goes into, but do not get the grinder in the water...
heatman101
Nov 25, 2010 | Microwave Ovens
Jura E8 beans will not pass through grinder resulting in "Fill Beans" error message. Saw reference to Kaffeestudio.com for dissasembly instructions but that link no longer works. I assume that the chute...
It seems withthis model you have a 1 year or 4000 cups warranty with this.
If you are within this, then give them a call - here is the Manual if you don't have it -
MANUAL -
I suggest you start by removing the beans in the hopper and wiping around to remove oils.
Then refill with fresh dry beans.
Plug in and set up as normal
Set to brew a standard large cup - and adjust grinder to coarse setting while grinding.
Do not adjust with grinder quiet - it must be done while rotating.
Make at least 10 cups this way at the coarse setting.
I think what has happened is that damp beans (frozen or cold) have entered the unit and caused the coffee to gum up at the top of the burr.
This will just push fresh beans out of the way instead of starting to grind them.
If you use dry (light loast) beans, it doesn't seem to happen as much.
Just ake sure you refrigerate most of your stocks, but keep a small stock at room temperature in an airtight tin to prevent this kind of thing.
You can actually push down on the bean stack slightly with a wooden object while the grinder is running if nothing moves on the coarse setting to get things moving.
Feb 10, 2010 | Microwave Ovens
GE over the range microwave making grinding noise
This sounds like the stirrer. If it sticks or stops, the microwaves can damage or destroy it. You may have a bad stirrer or magnetron. There is an important bulletin that covers these problems. To see if yours is covered, see: http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf If you need more help, please follow-up.
Apr 30, 2007 | GE JVM1650 1000 Watts Microwave Oven
Turntable Grinding Noise
It will need a new turntable motor. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Mar 21, 2007 | GE JVM1660 Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
