Question about KitchenAid KERC507 Electric Kitchen Range
Replacing bake element - KitchenAid KERC507 Electric Kitchen Range
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
Baking element broken after replacing not getting any heat from baking or broiling element, getting power cook top working, what else could be problem,
did you check the fuse
and if you know how to use multimeter then at least check voltage across the element
thanks
please rate my work
Aug 27, 2011 | Ovens
Was baking in oven on a baking stone and inside the oven there was a flash and loud pop (what you would expect if you had metal in a microwave). Is this worth the service charge to see if it can be fixed?...
Was the baking stone resting on the element? It sounds like the element has shorted out and it should have tripped the circuit breaker and/or blown a fuse in the unit. Replacing an element is not difficult and is carried out from the inside and the back if the oven. With the power off, locate which element has blown, it will probably be the bottom one and there should be a hole at the site. Remove the back if the unit, remove the wires from the element, remove any screws that may be holding itin place, ease the element out of any clips that retain it and pull it out through the front, Refitting the new element is the reverse of the removal.
Jan 18, 2011 | Amana AER5712AA Electric Kitchen Range
The elements will not heat up on bake.
The problem is the Bake heating element. This is easy to check and usually inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the testing and replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
May 02, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The broil element and bake element both come on set for Bake.
You are correct in your diagnosis. The selection switch has 2 sets of contacts that should only make one when on bake. The contacts internal to that fuse are most likely fused together, the other thing that could be going on is a short circuit in the wires to the selection switch causing the same problem. Typically a repair unless under warranty would be costly unless you are up for the challenge of replacing the switch and checking the wiring yourself.
Apr 20, 2010 | DeLonghi XU1837 Trilogy Bake 'N' Broil...
Wont heat past 200 degres
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Kenmore oven lower element sporadically heating.
Oven doesn't work after replacing the bottom (baking) element
Will the clock control accept the bake and temperature request?
If so,
You will need to remove the rear panel of the range and test the bake element leads for 220 volts when the oven control is set to bake and is turned on.
Mar 08, 2009 | Magic Chef CER3725AA Electric Kitchen...
Re: GE Electric Range JBP67BD1WH Baking Element Problem
Before you replace the range, I'd try replacing the oven temp sensor (part number WB21T10007 ) which is rather inexpensive. If I were able to get my hands on your range I'd first test to see if the control is sending 240 volts to the bake element. We know there is 240 to the range because the burners and broiler work, but is the control sending the full 240 to the bake element ? The only way for you to know this is to use a meter and test the voltage across the terminals of the bake element when in bake. Of course you should also test the bake element with power off and at least one terminal disconnected to see if you have about 20 ohms resistance across the terminals and no resistance from a terminal to the frame of the range. If not, you may need a new bake element (part number
WB44T10010 )
Let me know if I can be of further assistance. Thanks for using fixya.
If this helps, a fixya rating would be appreciated. Thanks.
Nov 08, 2008 | Kitchen Ranges
KitchenAid KERC507 Electric Kitchen Range Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
