Question about Fuji Electronics - Others
Fuji video cassette is out cassette
Rewind tape back into cassette
  • 130 Answers
SOURCE: Tape is stuck in VCR- Fast rewind and forward
It may need to be cleaned. Mechanical problems are one of the big problems with VCRs they use alot of mechanical moving parts and play for so long they fail. Plastic parts dont help much either. The pinch roller takes up the slack and is usualy the part that fails first because it constantly runs along the tape and builds a coating on the rubber so it doesnt grip the tape and pull it back into the cassette. If its not pulling the tape back in then it hangs up inside and you cant get the tape out. Fastforward uses the reels to pull the tape not so much the roller. Try and stop 2 times then fast forward then eject the tape. Try and eject the tape while its fastforwarding so it doesnt do anything else. Sometimes machines will unload after its been in fastforwad a while then it will eject. You will hear a change in the sound when it unloads, you can hear the mechanical arms move the tape in and out of the cassette. Thats when you eject it. You cant really clean it till you get the tape out. YOu can clean the pinch roller with fingernail polish or paint remover. It is a wheel inside it looks like a black tire. It pinches the tape against the capstan arm this is why it developes a film or a shine on the rubber making it slip.
Posted on Apr 04, 2006
ice man
  • 68 Answers
SOURCE: tascam 102 mark 2 cassette
there is a mechanical problem in your tape deck. probably a losen rubber band. it clicks because the rubber is too lose to move the mechinal parts. so when you power off, it losen the whole machanical parts..it is very easy to replace..opend the deck and check it out..good luck
Posted on Apr 15, 2007
  • 129 Answers
SOURCE: Video will not rewind to beginning of tape.
the clutch gear needs to be replaced . you can order the part partstore.com go by brand and model easy to replace around 30.00 dls .
Posted on Jun 20, 2007
SOURCE: DCR-HC42
  1. I'm having the exact same problem. It wont accept the cassette...only half way then errors. It will close fully without a cassette as well. hmmmmm
Comment by Guest, posted on Apr 02, 2008 Load cassette, turn it on, then message says re-load cassette. Door to cassette compartment only works half way. After fiddling with power, can get the cassette door to open and close all the way, but not with cassette. Tried several brands of cassettes, no joy.
Posted on Jul 10, 2008
SOURCE: Canon GL1 Remove cassette error
I certainly don't intend to be rude or obnotious but your comments on this known prpblem are contraditory to say the least! :
"The problem that you are experiencing with your Canon GL1 camcorder is a common complaint on this model camcorder. The “eject the tape error” is the camcorders way of saying something is wrong and it needs to be sent in for repair. It is not a defect with the camcorder, it is simply the most common complaint when the mechanical assembly is not running smoothly and perfectly." If something is wrong and it's a common problem then it must be defect?!?! Also your pricing for this "repair" is pretty close half of what a used GL goes for over here in Europe. I would definatly be looking for another quote and repair service other than yours!
Posted on Aug 20, 2008
Sharp camcorder vl- AG151u cannot get picture when playing a tape
sir
clean the video head with a head cleaning cassette, the cassette will play only for three minutes so that rewind the cassette and play 4 to five times .
Feb 01, 2016 | Sharp Video Cameras
Tape isn't retracted into cassette upon eject on Sony EV-C100
l would sacrifice a old or bad tape here, remove all the tape inside a cassette and tape off the small sensor holes on each side.
That way no tape to damage and you can insert it to see what is happening.
What likely is the issue is when stop it, it or if the tape does not fully load against the drum with heads, when the arms retract that pull the tape out of the cassette the mechanism is not switching to rewind it back into the cassette.
Usually this means a belt is slipping or the idler unit is not working---belts can break or stretch or even come off---belts will get slopply or bad from NO use and it is common.
Dec 09, 2012 | Sony Video Hi8 Ev-c100 Ntsc Video Cassette...
Where is the rewind on this cassette player?
Cheap cassette players have no rewind feature. This allows the mechanism to be simpler and cheaper; they just 'pull' the tape forward constantly, without the pinch wheel for "fast" [sic] and with the pinch wheel for "play".
To work out if this is the problem with your cassette player, look inside with no cassette inserted. If one of the spindles is plain, without the "three-pronged" device to engage with the spool, then you have the cheap device with no rewind. Turn the tape over, and fast-forward.
Jan 19, 2011 | Audio Players & Recorders
Eject cassette
sounds like already rewound or tape is caught open and have a look!!
May 15, 2010 | Canon DM-XM2 Mini DV Digital Camcorder
Reinsert cassette - After inserting a cassette the on screen message reads as follows "reinsert cassette" a further message C:31:23
when ever to get this kind of message just try to fwd the tape mannualy, or just make sure tht when u are rew. the tape dont rewind tht completely....
Jan 04, 2010 | Sony DCR-TRV285E Digital-8 Digital...
GE VG4056 will not rewind
The photo sensor that senses the tape end has blown or dry soldered.It is on the right side of the mechanical deck and senses the transparent end of the tape through the square hole in the video cassette.
Apr 27, 2008 | GE VG4056 VHS VCR
FUJIX-8 F60wide eats tapes when I rewind
You should e able to use any head cleaner, as long as it is the right size for you camera, but that is deffinitely your problem.
Feb 13, 2008 | Canon XL1S Mini DV Digital Camcorder
How to rewind tape?
PRESS THE BUTTON TAKE LOOKS LIKE THIS --> <<
Feb 11, 2008 | Panasonic DVM80 Digital Video Cassette 80...
Basic Functions Don't Operate Near End of Tape
Defective optical end-of-tape sensor, or alignment of those related component....accordianman
Dec 01, 2007 | Mitsubishi HS-U775 S-VHS VCR
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
Electronics - Others Logo
37 people viewed this question
Top Fuji Electronics - Others Experts
Are you a Fuji Electronics - Other Expert? Answer questions, earn points and help others
