Question about Video Game Consoles & Games
Ps3 ip address timed out - Video Game Consoles & Games
4 Suggested Answers
  • 51 Answers
SOURCE: setting up wireless connection on ps3
u have to set your IP on your modem settings to static IP
Posted on Nov 18, 2007
chris252
  • 84 Answers
SOURCE: Ps3 Unable to obtain IP address and connect to internet
maybe the modem set is different from the modem in the lap top in other words maybe you ps3 needs higher and better connection
Posted on Mar 31, 2008
perpetually
  • 360 Answers
SOURCE: cant find ip address on ps3
If you are directly wired to your modem (not router), you will have to reboot your modem each time you switch between computer and console. When the modem boots up, it leases an IP address to the MAC Address of the connected device. Each device has a unique MAC Address. If the MAC Address does not match to the one it leased an IP to, it won't allow access to the internet.
You can get past this by "cloning" the MAC Address of your computer to your console.
To get the MAC Address (Physical Address) of your computer:
XP: Open the start menu, click "run" and type "cmd" then hit enter. A black screen with white writing should have opened. Type in "inconfig/all" and hit enter. Look for the line that says "physical address". That is your MAC Address.
Vista: Open the start menu, in the search bar type in "cmd" and hit enter. A black screen with white writing should have opened. Type in "inconfig/all" and hit enter. Look for the line that says "physical address". That is your MAC Address.
Now get into the network configurations on your console, look for an option of MAC Address cloning. Input the MAC Address of your computer, save and reboot.
Hope this helps.
Posted on Sep 15, 2009
My PS3 can't find the IP address for my wireless router and I don't know how to enter it
possible cause is that ps3 uses an ip address leased from the wi fi router via its DHCP Server in Router. If PS3 was off for a while another computer on Wi FI network may have been assigned the IP address that the PS3 thinks it has.
Try page 29 of
http://au.playstation.com/media/2Pv7AFEC/CECH-2102B_2103B-3.20_UKANZ[EN]_vf1.pdf
on page 31 change the ip address setting to manual
set ip to 192.168.0.254 subnet mask 255.255.255.0
Now exit setup
Then go back into Setup
Change IP address setting to Auto
Why
This will renew the ip address from the DHCP server to the ps3 hopefully allocating you a fresh IP address lease .
Feb 19, 2016 | Sony Playstation 3 (PS3) Console
Ps3 says ip address timed out / wep key was entered incorrect.
Have you tried manually adding a IP to your PS3 ie if your routers ip address is 192.168.1.254 set your PS3 to 192.168.1.60, with a subnet of 255.255.255.0 and set the gateway to the IP address of your router in this example it would be 192.168.1.254..
May 03, 2017 | Sony Playstation 3 (PS3) Console
Trouble obtaining ip address
When you put the IP address in you also have to add your DNS settings. easiest way to find your DNS server address is to use an XP based machine and type "ipconfig /all" it will list all of the properties of your computers network card. thake those DNS address' and plug them into your PS3.
Sep 13, 2009 | Sony Playstation 3 (PS3) Console
My ps3 says time up on obtaining ip address
Make sure you are trying to access the right WEP type. I'm using a WPA2, should give you the option
Make sure in the settings and connection list that your address settings are set to automatic. I found that manually setting my internet connection settings so I could put the UPnP as disabled helped me.
or just type 192.168.1.1 or 192.168.0.1 into your web browser and your login for your router will pop up from there you can turn off your wep so it doesn't need a pass.
Thanks.
Jun 13, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont pick up my I.P. address
Try to enter the address manualy, you can choose the number after the one you have on your PC.
Apr 11, 2009 | Sony Playstation 3 (PS3) Console
Playstation3 can,t pickup ip address
If you have your internet to your computer and the PS3 you need a router to provide an IP for both. Otherwise your ISP will only provide an IP for what ever was hooked up first most of the time. If this is the case try only the PS3 and do the auto setup. Linksys is a simple router with great support. If there is already a router hooked up please clarify.
Mar 21, 2009 | A.L.S. Industries Messenger Bag for...
My ps3 internet doesn't work
Easy Pie! This is a cinch anda guarantee work through. It involves putting your PS3 into a DMZ (demilitarized zone) which simply means opening all of the ports on it.
If you have the following problems, this is likely to fix it.
  • Not being able to join rooms
  • Not being able to speak over your headset
  • Not being able to hear other people over their headset
  • Not being able to join private games
  • Any problems to do with connectivity to the PSN, especially if your computer will connect to the internet, but your PS3 won't.
Part 1-(On PS3)
  • Firstly, you will need to assign your PS3 a static internal IP address. Normally whenever a device connects to your router it will be assigned a different internal IP address. These are normally 192.168.1.2, 192.168.1.3, 192.168.1.4 and so on. Assigning a static one will ensure that your PS3 will get the same one every time it connects.
  • Go to the "Settings > Network Settings > Internet Connection Settings" option on the PS3 XMB. Choose whether you are using wireless or wired.
  • Both selections should show a page called "Address Settings". Here you will need to select "Custom". Another page will then display entitled "IP Address Setting". The option "Manual" will need to be selected.
  • This will display a page where customizable IP Addresses are available to be entered.
  • IP Address - This will need to have the Static IP address in it. Use 192.168.1.80, simply because it is unlikely that 80 other devices will be connected at the same time.
  • Subnet Mask - always set to 255.255.255.0
  • Default Router - Is the internal IP Address of your router.
    1. To get the exact ip of your router you should go to
    2. Start
    3. Run
    4. cmd [Hit Enter]
    5. Type in ipconfig and hit enter, this should come up with all the ip addresses to do with your computer and the network. The address you will need to enter in this option is listed as "Default Gateway".
  • Primary DNS - Same IP Address as "Default Router"
  • Secondary DNS - Same IP Address as "Default Router"
  • Proxy � When you get to the proxy screen, select "Do not use Proxy"
  • MTU � Automatic
  • UPnP � Enabled
Part 2-(On PC)
  • In your Internet Browser, type the address of your default gateway, this will take you to your Router Configuration Page. Look for any mention of DMZ
  • When you have found this, it will ask you for the Static IP of the DMZ host. This is simply the Internal IP that you assigned your PS3. We used 192.168.1.80.
  • Finally, turn off your Router, PC and PS3 for a few minutes to ensure that the new settings are loaded. Then you're ready to go!
Courtesy of http://www.cod4forums.com/index.php?showtopic=3460
Feb 03, 2009 | Sony Playstation 3 (PS3) Console
Ip and proxy error
well, if you know how to setup the ip addresses manually both on your modem / router and on the ps3 i recommend you do that... but bear in mind that your dhcp server (on your modem / router) should prohibit automatic assignment of that same ip address with your ps3... for that you have to specify a range of automatically assignable ip addresses apart from your ps3...
if you have the dmz (demilitarized zone) option on your modem / router, set it up for the ip address of your ps3, which you've setup manually...
example:
router ip: 192.168.2.1
ps3 ip: 192.168.2.10
ip address pool: 192.168.2.100 - 192.168.2.250 (this shpould be manually setup not to interfere with the fixed ip address of the ps3)
dmz host: 192.168.2.10 (ip address of the ps3, which enables "opens" all of the ports for this ip address)
apart from that if you use any proxy servers to connect to the net, you have to specify these in ps3 settings as well...
there are a lot of threads on various forums on how to tweak your network connection to optimize for ps3...
i hope this solves your problem...
Feb 19, 2008 | Sony Playstation 3 (PS3) Console
Ps3 ip address problem
when tring to test connection it says ip address failed
Feb 13, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
71 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
