Question about Nordic Track NordicTrack Elite 7500 Treadmill
Display console won't turn on norditrack - Nordic Track NordicTrack Elite 7500 Treadmill
I have a 2012 Norditrack T7.0 treadmill and the console has some of the writing and number areas "blacked" out. Any ideas on how to troubleshoot this so I can see the full image?
Unfortunately, the only thing you can do is replace the whole console. Nordictrack makes their consoles all but unserviceable so that you have to buy a whole new one.
May 31, 2017 | Exercise & Fitness
Norditrack E7 SV display malfunctioning.
The control panel is defective is the most likely cause.
Jan 18, 2017 | The Video Game Consoles & Games
Have a norditrack T7si that stop working in the panel but just half of it.. the other half buttons work good and the treadmill doesn't have any other issue. Help please!
More than likely the console needs to be replaced. There is not repair available, the entire console will have to be replaced.
Oct 27, 2015 | Exercise & Fitness
Ifit card reader on my norditrack C2255 dosn't work.
Sounds like card may have lost the data. This can happen if static discharge causes the card information to vanish.
Feb 26, 2014 | Exercise & Fitness
Norditrack a2550 model stopped working while I was on it. The control panel will beep then light up like a Christmas tree but just goes into a nonperforming demo mode. Treadmill wont work! Help
follow this steps and fix it. God bless you
1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 06, 2013 | Nordic Track NordicTrack Treadmill, A2550
Nordictrack Commerical 1500 - Display Failure/Won't Turn On
There can be a few reasons,
Lume
LCB
Console
Is it under warranty ?
Jan 25, 2012 | Nordic Track NordicTrack Commercial 1500...
I have a norditrack exp 1000x, on the lower part,of the control panel,the functions,have stopped working.but the upper function keys are ok.what do think is wrong.?
The overlay is bad. You will need to replace the whole console because nordic track does not sell just the overlays. you can get the console at iconservice.com or check on ebay
Aug 11, 2010 | Nordic Track Nordictrack Exp 1000...
Nordic Track NordicTrack Elite 7500 Treadmill Logo
42 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
