Question about Building Materials
Ripfence illistration for foley belsaw tablesaw model 490
2 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: lock fail to open, L1000
Start with a puff of graphite dust, and work the key in and out of the lock, causing the rake on the end of the key to move the pins and springs up and down. Do this several times. Then, place the key in the lock, but not fully. Leave the key out of the lock 2 pin's worth. Tap the back of the key with a screwdriver **** (like a hammer blow, but softer), while applying slight pressure in the direction that you want the lock to operate. This is known a springing the lock, and is quite easily done, if you already have the right key. Don't give up, it may take up to 20 attempts to get the lock to spring. Each time that the lock doesn't move, return to the "locked" position, reset your hey to the "two pins out" position, and tap again. Once the pins clear the shear line, open the lock. Re lubricate the lock after it has been opened, and you are ready to lock it back.
Best regards,
--W/D--
Posted on Jan 21, 2011
How to change cutter blades on Foley Belsaw thickness plain 910?
Try this link: http://www.kent.co.in/pdf/Kent_Grand.pdf
Jun 30, 2014 | Tools & Hardware - Others
How to assemble a powermatic powerfeeder model number pf-31 to a tablesaw sawstop model number ics53230?
As far as mounting, you may have to drill some holes in your table. Or get the quick mount from Grizzly Ind. There should be a gap between a couple of the rollers. This is where the blade sits. Dont let the blade cut into the rollers though. Set it at a very slight angle to keep the wood against the fence. Try it without cutting wood first. Hope this helps, and good luck!
Sep 11, 2012 | Powermatic Pf-31 Powerfeeder, 1Hp, 1Ph,...
I own a 10" craftsman tablesaw (model #
Wait for the motor to cool then try again..... you may use compress air to blow across the motor to speed the process.
Jan 19, 2011 | Craftsman 10" Table Saw
Panafax UF-490 fax problem
your lsu unit must be dirty or check your drum unit
Feb 25, 2010 | Panasonic Panafax UF-490 Plain Paper Laser...
The brushes are gone in the motor of my mastercraft tablesaw
Send me your email address with the model # and Type (1,2,3 etc..) and I'll help you get them. Send request to: desertairrepair@aol.com.
Feb 08, 2010 | Delta 10"Hybrid Tablesaw with 30"Unifence
I need a table saw motor model rm871 where can i go to get it?
Sears.com would be the only place that I know of, I also think that the motor number has changed,
Oct 02, 2009 | Saws
Need motor for craftsman table saw model rm871
Go to midlandhardware.com.For about $4.00 more than just price ofthe motor,you get the complete saw 15amp.motor with a laser guide!The table saw has a 3yr. warranty,3 extension wings,and a sturdy stand.Shipping to your door $24.00,$198.58 total.
Jul 03, 2009 | Craftsman Saws
I have a Craftsman table saw with a burned out motor. The motor model number is RM871. Where can I find one for less that the $130.00 that Sears wants for the motor. That's the price of the saw.
SOUNDS LIKE THE PROBLEM I HAD, BUT WAS JUST A SEIZED-UP BEARING. I WENT TO LOCAL ELECTRIC MOTOR REPAIR ($15.74) PARTS AND LABOR, THEY REPLACED THE BEARING, THERE ARE 2 BEARINGS ON IT, COST IS THE SAME FOR EACH. THE BEARING IS PRESSED ON, SO REPLACEABLE. HOPE THIS HELPED
Mar 27, 2009 | Craftsman 10" Table Saw
Sears Craftman Garage Door
I enrolled in the Assistant Premium Plan and am waiting on a response.
Apr 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
104 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
