Question about 2011 Chevy Equinox - LTZ, with factory rails - Base Rack System
How do i check the awd fluid in a chevy equinox 2.4?
2.4 liter engine
  • Rhino-Rack Master
  • 1,051 Answers
If you raise the hood and standing in the front of the motor look to your right and down there should be a cap with a dipstick attached that will check the fluid. It is part of the drive unit for the wheels and it is marked. Once you unlock it to the left you will need to tug on it as it has a splash guard attached to it inside.
Posted on Dec 24, 2015
Where is the location of the oil pressure sender on a 2014 awd Chevy Equinox?
The AWD Equinox has two model selections (LS & LT) and two 2.4L engine options (K2.4L FI DOHC & the K2.4L Flex Fuel DOHC.)
Information on the Equinox engines oil pressure senders location is difficult to find on line so all I can offer in the way of help is to say that It will be on the engine block connected to the ECM (engine Control Module) with a single TN/BK (Tan/Black) wire lead.
The Oil Pressure Sender is a distinct looking unit that is sold by Autozone and they provide pictures of the various makes which should help you identify the units location on your engine block.
Gauge Sender
Aug 07, 2016 | Chevrolet Equinox Cars & Trucks
3.8l awd. how much transmission fluid goes in to a completely empty system,and what type of oil for transfer case.
Reference: 3.3/3.8L Fluid Capacities & Specifications - The ...
forum.chryslerminivan.net/.../12671-Reference-3.3-3.8L-Fluid-Capacitie...
May 8, 2009 - 10 posts - ‎2 authors
FLUID CAPACITIES Fuel (Approximate) - 20 US Gallons (76 Liters) Cooling System* 3.3 and 3.8 Liter Engines - 13.23 Quarts (12.5 Liters) NOTE: - *Includes heater and ...1996 Chrysler Town & Country LX [Always and forever the favorite.] ... Does anyone know what the transmission fluid capacity is?
1998 CHRYSLER TOWN AND COUNTRY 3.3L 6-cyl Engine ...
www.amsoil.com/.../vehiclelookup.aspx?...1998+CHRYSLER+T...
Amsoil
Dec 29, 2015 | 1998 Chrysler Town & Country
2003 Chevy Astro van AWD jerks sharply once when going freeway speeds...does not do it "around town" and feels like vehicle is being kicked from behind. Rear disk brakes recently replaced. It is inter
this may be coming from an axle"{ wind up" situation occurring when the diff between the front and rear diffs is not working properly. If you have traction control I would suspect a faulty sensor. Have the fault codes read to make sure
Mar 28, 2013 | 2003 Chevrolet Astro
2005 Chevy Equinox 3.4 Liter engine. Do I need to shim under the rocker arm pedistals after taking .003" off the head.
No that is an acceptable loss of clearance, it will be absorbed by the hydraulic followers.
Oct 29, 2012 | Cars & Trucks
2005 Equinox: 2005 chevy equinox vibration at low speeds...
A low speed vibration is likely caused by a tire. Check to see if any rims are bent. Have the tires checked and replaced as necessary. If the tires are worn unevenly have an alignment done. If this is an AWD model check the driveshaft and support bearing.
May 18, 2010 | 2005 Chevrolet Equinox
How to check transmission fluid level
Unfortunately you can not. Chevy put sealed transmissions on most of their cars starting in 2006. It would be out of luck if you got one without a sealed transmission. If you did, look behind the engine on the passenger side for a dipstick similar to your oil dipstick. If you dont see one, you will have to go to the dealership to have it checked.
Feb 25, 2010 | 2006 Chevrolet Equinox
Where is the fuel filter on a 2008 Chevy Equinox LTZ AWD 3.4 liter engine? I traced the fuel lines from the gas tank to the engine and I don't see what would look like a inline fuel filter.
Most filters are located eather under the the car by the driver or rider door. But there are some case's if have seen cars only having a filter on the pump in the tank.
Jan 24, 2010 | 2008 Chevrolet Equinox
2005 chevy equinox, washer motor working but no fluid is coming out to either front or back
hiya
it uses one washer fluid tank in the engine area that provide fluid for front/rear windows.
you could pull the rubber hose off at the bottom as a first check to ensure the washer pump does function to shoot fluid from the washer fluid tank.
if there's fluid still in it, look inside to ensure no forgein/gunk object is plugging the bottom inside.
check the washer fluid tank in the engine area and see if the rubber hose is still connected to it?
also check for no kinked or pinched point along the hose...just follow the hose to see it's not compressed flat which could be the cause of restricted washer fluid movement.
Feb 23, 2009 | 2005 Chevrolet Equinox
2011 Chevy Equinox - LTZ, with factory rails - Base Rack System Logo
41 people viewed this question
Top Rhino-Rack Vehicle Parts & Accessories Experts
Shaun Thompson
Shaun Thompson
Bill Boyd
Jerry Ross
Jerry Ross
Are you a Rhino-Rack Vehicle Part and Accessory Expert? Answer questions, earn points and help others
