Question about Samsung HL-R5656W 56" DLP HDTV
How do I replace the lamp in a HL-R5656W
Need instruction on replacing the lamp
asnowman
  • 788 Answers
SOURCE: installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jun 01, 2009
  • 336 Answers
SOURCE: Replaced lamp. TV does not respond
Hi, do you hear clicking or like a start up sound? if you do it could be an issue with the ballast,that's the board that powers the lamp.Here's how to replace it: http://guides.fixyourdlp.com/samsung/bp47-00033a.php Does your TV make a "whining, whirling, clicking, or humming noise?" If the TV have the infamous blinking lights problem and you're replaced your lamp without success, it's most likely a problem with your color wheel. The Samsung BP96-00674A color wheels spin anywhere from 6,000 to 15,000 revolutions per minute (RPM’s)--It is one of the few consumable parts in your Samsung TV. The average life expectancy from our data logging shows the Samsung color wheels are fairly reliable with a MEAN average of 5-8 years. Here's how to replace it:http://guides.fixyourdlp.com/samsung/bp96-01579a.php Also make sure door cover is properly shut and also reset lamp timer by unplugging tv wait 5 min and plug it back again.God bless you!
Posted on Sep 30, 2009
SD Tech
  • 14553 Answers
SOURCE: I need to replace the bulb on my TV model #
This model does not use a lamp----if the LED unit is bad you may want to just forget it---
Samsung part number for the entire optical engine:
BP96-01470BIt is marked as no longer available (2006 model) and had a suggested list of 495 exchange.
Google the above part number and you will find some places selling the engine---for much more than Samsung wanted.
SORRY TO GIVE YOU BAD NEWS---no replaceable lamp in this model----the LED light unit is part of the optical light engine.
SD TECH
Posted on Oct 28, 2009
johnnydiode
  • 647 Answers
SOURCE: HL-R5656W
Wait until you get the new bulb to determine that. The old bulb is probably arching as it tries to start.90% of the time the new bulb will do the trick.
Posted on Oct 31, 2009
Testimonial: "A quick answer back, with good insight. "
  • 304 Answers
SOURCE: my tv have vertcal lines wend I just tern on but
You are probably seeing what looks like Jail Bars (Vertical Lines evenly spaced) on the screen. If so,then the DMD chip on the DMD board is bad and needs to be replaced
Posted on Apr 14, 2010
Samsung lamp is stuck
Hello
It is best to get it service by the technicians from the authorised Hitachi service center, because,it light engine should be checked and cleaned. It is really a very skilled work, and can't be done without proper tools and sound expereince. Just call the service center and ask of service. OK.
Nov 25, 2011 | Samsung HL-R5656W 56" DLP HDTV
My Tv's problem started with a loud whining sound that lasted about 4-5 days. It then subsided but was quickly replaced by a constant lower humming vibrating sound. I've changed the lamp so i know thats...
tomscientzas,
Sure do. You have a bad color wheel which needs replaced. I have a tip at
http://www.fixya.com/support/r4160054-replace_color_wheel_in_dlp_projection_tv
which explains how to repair you unit and where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
Mar 01, 2011 | Samsung HL-R5656W 56" DLP HDTV
My HL-R5656W made a popping sound and the screen became black. We ordered a replacement lamp and replaced the old broken lamp. The popping sound stopped but the screen does not come back. The LAMP light...
hi,
Check the lamp colling fan is it working or not. Also check the connection on the lamp holder is proper or not, possibility of connector burning . then, you have to check the lamp power supply. check the fuse in it. if all these are ok then you have to change the lamp power supply.
ok
Feb 06, 2011 | Samsung HL-R5656W 56" DLP HDTV
Pic will not come on
you need to replace a lamp to correct this issue
Dec 18, 2010 | Samsung HL-R5656W 56" DLP HDTV
I have a 2 inch wide dim (colorless) strip down the left side of my HL-R5656W. It happened after a move. Could I have jostled anything? How do I fix this?
yes you could have. Try 2 sources, cable, dvd, game system. If the issue is with any 2 then it is the tv and it will have to be adjusted by a repair center. If it's only one source then it could just be the actual source that the issue is with. You can also push the menu button and if the line is over the menu it's for sure the tv.
May 05, 2010 | Samsung HL-R5656W 56" DLP HDTV
My tv have vertcal lines wend I just tern on but wend heat up dosent do any more ?? Samsung HL-R5656W 56 in. HDTV DLP TV
Apr 03, 2010 | Samsung HL-R5656W 56" DLP HDTV
HL-R5656W Unit made loud pop and pic went black, ordered bulb but there is a loud crackling with some flashing going on when I re-inserted old bulb, is this the ballast that needs replaced?
Oct 31, 2009 | Samsung HL-R5656W 56" DLP HDTV
Tv will not turn on
Check to see if there is a problem with the internal fuse. Your user manual should have a troubleshooting section that will address your particular symptoms.
You should also plug a different appliance into the outlet where your TV is plugged in to make sure there isn't anything wrong with the outlet.
Though this probably isn't the case, I have sometimes seen outlets that are controlled by a wall switch, and sometimes, the wall switch is accidentally turned off.
Jun 20, 2009 | Samsung HL-R5656W 56" DLP HDTV
Samsung HL-R5656W 56" DLP HDTV Logo
21 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
