Question about Vacuums
Model 7901 Clogged water line
3 Suggested Answers
VacuumRepair
  • 438 Answers
SOURCE: Bissell Proheat model 7901-1 is there diagram of
I have pasted a link to the Bissell ProHeat series carpet extractor repair guide below. This guide is like my Bible when I'm working on these machines, and is EXTREMELY helpful on explaining how, and where hoses and parts go, and possible explanations of problems, and how to fix them.
I hope that this information is helpful to you, it sure is to me. If you did find this helpful, please be so kind and vote my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair. This is what really keeps repair professionals like myself keep coming back and giving free repair advice, we greatly appreciate when people acknowledge our work here. Thank you ahead of time.
Bissell ProHeat Repair Manual
Thank you again,
Chris J.
GoVacuum.com
Posted on Apr 15, 2010
  • 3 Answers
SOURCE: Manual says series 7901 and series 8910. Won't
In order to spray anything out of this machine, you need to have water in the bladder and water or solution in the smartmix bottle. If you don't have both, it won't work. Try this first, if it doesn't work you can access the tubing under the housing cover. You'll need a phillips screwdriver and pliers. Lay the machine handle down and take out the water bladder. There are two screws just in back of the bladder compartment; two in the middle of the compartment and two at the front of the floor noozle. You will also have to loosen and take off the round clear cover, red pinwheel and white strainer of the smart flow. (Mine is on the top left of the cover). Take the screws out and gently lift the cover up. This exposes all the tubing, the pump, etc.
I took off each hose separately and used an air canister to make sure the tubes weren't clogged. I just couldn't figure out how to get to the two ends that go into the inside of the wheel.
I hope this helps.
Posted on Jun 01, 2010
Bissell model 7901-1 won't dispense The pump turns, belt looks good Fluid from the reservoir is seen with a couple of bubbles in the inlet tube. It sloshes back and forth but doesn't get going
It's one of two things:
1. The Bladder may be empty. Remember, the bladder is inside the reservoir, so the bladder may look full, but in fact could be empty.
2.Or the lent screen may be clogged.
Jim
Oct 07, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Machine w/not squirt
have you check the spray nozzle or spray line for s clog? only other thing you didn't list? let me know?
Aug 23, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
I hope this helps.
May 19, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Thank you again,
Chris J.
GoVacuum.com
Apr 10, 2010 | Bissell 7901-R Clearview Proheat Plus...
PROHEAT BISSEL MODEL 7901-1
inside the upper part of unit there is a metal heating element which the water passes through, its probaly clogged,,,it gets filled with calcium build up from water..in future use distilled water or boil water before putting into these units
Dec 10, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
My steam machine will not spray water on to carpet why
clean the heater out it may be clogged with dry soap and water
Dec 28, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Water doesn't come out my Bissel rug cleaner model 7901
The flat belt on you machine has an access panel to it from the side of the machine. That belt runs the pump if it is broken or came off the machine won't pump.
Check to make sure both of the red/black circular rubber gaskets on either solution or recovery tank are on the tanks and not stuck down inside the inlet valves on the machine itself.
Make sure there is fluid in both tanks. Without fluid in both tanks the pump loses prime and will not work.
If all that checks out then you are down replacing the pump, but usually when the pump goes out, you will have a short burst of water when you first turn it on and then it stops working.
Hope that helps you out-Good Luck
Nov 11, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Singer by ryobi turtle plus carpet cleaner model ms4000
Will water squirt out the hose? If it does then the heater in the handle may be clogged and not allowing water to flow. The heater is in the handle. There are a number of things that can cause your problem. If no clogged heater and lines, and no water from the hose, then the pump or pump belt maybe bad, the cap for the flow indictor is leaking air and not sealing, the gasket at the bottom of the tank isn't on the tank, either missing or sitting in the hole in the base where the tank sits.
Here is a link you may find useful:
http://bissell.com/images/Schematics/7901.pdf
https://bissell.com/NewsLetters/ListArticles.asp?Page_id=27960&Article_id=132
Feb 21, 2008 | Bissell 7901-7 Proheat Upright Vacuum
No water spray
Does water shot from the hose when you depress the trigger? If it does, then the heater in the handle may be clogged and will have to cleaned out or replaced. If no water squirts out the hose, then check the bottom of the bucket, make sure the gasket or seal is on the auto-load on the bottom of the bucket and not in the hole. The red flow indicator cap may be loose or leaking air. Could have a clogged or pinched water line under the top housing.
Jan 31, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix know. Pump is bad.
Oct 11, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
12 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
