Question about Refrigerators
My ice maker is leaking
My kenmore ice maker is leaking into my frezzer
  • Victor
    Victor May 11, 2010
    Hi, Can you see if it is leaking between the head and the ice tray or is it leaking as if it's filing the icemaker to much?
    Please let me know if I can assist you further.
    Vic
  • 25 Answers
The icemaker fill valve is probably leaking thru, its located on the backside of your fridge, just follow your water line, the valve is pretty easy to change out and will cost you less than 40 dollars
Posted on May 21, 2009
How do you get to the drain pan?
the pan is still at the bottom next to or below the compressor. access is from the back of the frig. but you might find it to be dry due to evaporation.[heat from the compressor] if you have water on the floor and have an ice maker, than that is your problem. a water line leak [possibly]!!!!!!
Nov 09, 2009 | Kenmore 53642 / 53644 Side by Side...
My ice maker just stoped working I have another refrig at the camp that is the same refig I just never hooked up the ice maker how do I take them out of the frezzer and swap them?
ONE THING YOU CAN TRY IS POURING WATER IN THE TRAY--LET IT FREEZE--IF IT DUMPS IT OUT THEN IT IS YOUR WATER VALVE. IF NOT THEN REPLACE ICE MAKER
Oct 28, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Ice maker stopped making ice
Pour about 1/2 cup of water into icemaker . If it dumps , replace the water valve . If doesn't dump , replace the icemaker . Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | Refrigerators
Refrig/freezer not cooling/freezing
your gonna have to let thr fridge defrost buy shutting it down because it soundsm like you have either a build up of ice it the vents in the back of the frezzer unit also check to see if you can hear the fan working in the frezzer if not that would be you main problem
Jul 26, 2009 | Freezers
My chest type freezer ice up around the top but does not freeze except in the bottom portion
Check the gasket. Sounds like you have a leak somewhere causing the ice formations on the bottom. Easy way to check this is to have a steamer or a small pot of boiling water (steaming hot) while the frezzer is runing hold the pot of steaming water and watch the steam. You will see the steam going into the frezzer. BINGO leaking gasket. May need to replace the gasket or may beable to fix. You will see and know what to do. Keep me posted. Good luck.
Apr 06, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Ice maler water leaking
Found that ice had accumulatd in the refill cup that prevented the water from filling the mold so that it spilled over into the frezzer compartment
Mar 25, 2009 | GE Refrigerators
Water inlet ot ice maker leaks in to frezzer
Change the Water enter dump valve for the ice maker. It is leaking. It will not shut off & will cause this problem. It`s infrequently located in the rear of refrigerator ussualy where water line enters the electrically back of refrigerator. In essence the valve and electric head can be bought at any Appliance Parts store. It`s not a high cost part and be bought easily for it is mostly a standard part to buy. erroneously bring the model number and serial number and they can get the right one to replace it with.
Jan 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker and water dispenser not working
well there is two things it could be low water pressure or ur ice maker is defective try replaceing the ice maker this should work if not u need to get a frig repair man out to help u because if the problem is in the frezzer door it is not easy to fix on ur own
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
Refrigerators Logo
822 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
