Question about Shop Vac Vacuums
Shop vac whistles
2 gal shop vac has high pitch whistle, ear piercing loud...
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 55 Answers
If you let it continue, you will have a piece of junk. You take the bolts off holding the motor cover on and you lubricate the upper bushing with oil. They are oil impregnated bushings and will soak up a thin type oil best and last longer. Use 10W or 3-in-1 oil or Marvel Mystery oil.
Posted on Oct 05, 2014
5 Suggested Answers
ukvacfan
  • 328 Answers
SOURCE: ear piercing whistle
Its an inherent problem with any Dynammite model = the fact that the motor is at the front means that it is extremely noisy.
Posted on Nov 16, 2007
redbeard00
  • 957 Answers
SOURCE: My Kirby G3 makes a loud, high pitch whistle with the hose
I would say you either have something stuck on the impeller or there is a piece of paper or something stuck inside the hose. its not clogging the hose but when the air passes by it. It is making that noise. If you find nothing you may need a repair. May have a bad bearing in the motor. Actually you can also try inspecting the brush on the head. It removes easily from vacuum and should spin freely and quietly.
Posted on May 04, 2009
SOURCE: when vaccuming with the hose it has a high pitch
try taking the hoses off, first. Check and see if their is a clog. Ususally if their is one, its in the unit itself and not the hoses. TO get at the clog, try using a metal cloths hanger. Its the only thing i have found around the house that works at getting at clogs.
Posted on Oct 23, 2009
tbreeze47
  • 3083 Answers
SOURCE: I have a Fein Turbo
It sounds like the bearings in the motor are shot. You can try to get a replacement motor, or if you're a mechanical genius type, you might be able to repair the motor bearings. If the shaft is worn, you'll have to buy a new motor.
You can try oiling or greasing them, but they're hard to get at (and sometimes sealed) and this rarely has worked, in my experience.
Good luck, and hope this helps.
Posted on Nov 20, 2010
My dc33 brush bar won't spin and there's a high pitched whistle. The belt seems to have plenty of tension and I tried the clutch "reset" trick. What do I do next?
Your belt may look fine and spin the brush roll but could still be slipping. There are two belts on your model if it has the clutch to shut off the brushroll. The whistle sound usually indicates a clog or restriction somewhere.
Jun 03, 2015 | Vacuums
High pitch whistle when shark ep754 turned on
sounds like you have some thing stuck in the hose
Dec 28, 2014 | Shark Vacuums
Why has our dyson dc14 started to sound out a high pitched whistling noise and lift the exhaust filter breaking the lid ?
Hi there, it's Jack at Dyson.
A whistling noise from your DC14 could suggest a seal or component is out of place. I'm sure we can help trace the issue, and it may be a simple fix.
When you have your vacuum easily to hand, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 13, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Filter whistle noise
Hi Basil,
I am sorry to hear your machine is emitting a high pitched sound. Based on the details you provided the problem may be isolated to the post motor filter, if so a new filter will be needed. We would like to help with this. Please contact our Helpline to speak with an expert:
US - 1-866-693-9766 or UK - 0800 298 0298
Best wishes,
Jessica
Sep 01, 2013 | Dyson DC25 Vacuum
My vax vacuum has started making a high-pitched whining/whisting noise
Ususally this is caused by a forein object has gotten hung in the suction impeller attached to the motor. the noise flucuates due to the housing flexes with the movement of the handle and rod. the housings are usually made of plastic and something very small can easily get stuck in it and stay for a very long time. The vacuum needs disassembled and the forien object removed from the fan housing...
Hope this helps
Sincerely
Roger
Feb 07, 2012 | Vacuums
Makes a terrible loud noise. It hurts my ears.
time to check your filters
if you bought it used check your hoses also
some people think sunp pump hose is just like vacume hose but man does it whistle (almost enought to pop your ears loud )
Jul 29, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
May 04, 2009 | Kirby G5 Bagged Upright Vacuum
Hoover bagless windtunnel has a whistle
when you take out the canister to dump it, there is a filter on the bottom.. take off and shake it out then put it back.. there''s also one on the top!!so when you replace thaton..look directly above that surprise anothe one do the same to that one and wholah like new
May 23, 2008 | Hoover U8147-900 WindTunnel V2 Bagless...
Ear piercing whistle
Sep 30, 2007 | Dirt Devil M084600 Dynamite Bagless...
Vacuums Logo
400 people viewed this question
Top Shop Vac Vacuums Experts
Mike
maple flats
Level 1 Expert
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
