Question about JVC Car Audio & Video
Usb device isnt being read when changed to the usb function
Make sure you have the USB device formatted as FAT and not NTFS, it won't read NTFS. Pretty much all car radio/head units are like that. Don't make seperate partictions, just one, it won't read more than one partition. Hope that helps.
Posted on Dec 22, 2014
How can i play videos from a USB with a Kenwood DDX715WBT i tried MPEG-2, WMV, DIVX, AVI, but it doesnt play it shows Unsupported File.
These excerpts from the user's manual....
USB
Connecting a USB device
You can connect a USB mass storage class device
such as a USB memory, Digital Audio Player etc. to
the unit.
• For details about connecting USB devices, see
page 70 .
• You cannot connect a computer or portable HDD
to the USB input terminal.
• For playable file types and notes on using USB
devices, see page 75.
When a USB device is connected...
The source changes to
"USB"
and playback starts.
• All tracks in the USB device will be played
repeatedly until you change the source.
[PAGE 75]
USB playback
Playable files on a USB device
• This unit can play the following types of files
stored in a USB mass storage class device.
- JPEG/BMP/PNG/MPEG1/MPEG2/MP3/WMA/
WAV/AAC/FLAC/H.264/WMV (VC-1)
• This unit can recognize a total of 5 000 files and
250 folders (a maximum of 999 files per folder).
• Make sure all important data has been backed up
to avoid losing the data.
Notes on using a USB device:
• This unit may not play back files in a USB device
properly when using a USB extension cable.
• USB devices equipped with special functions such
as data security functions cannot be used with the
unit.
• Do not use a USB device with 2 or more partitions.
• Depending on the shape of the USB devices and
connection ports, some USB devices may not be
attached properly or the connection might be
loose.
• This unit may not recognize a memory card
inserted into the USB card reader.
• When connecting with a USB cable, use the USB
2.0 cable.
The maximum number of characters (when the characters are 1 byte):
- Folder names: 128 characters
- File names: 128 characters
• Avoid using the USB device if it might affect
driving safety.
• Do not pull out and connect the USB device
repeatedly while "Reading" is shown on the
screen.
• Electrostatic shock at connecting a USB device
may cause abnormal playback of the device. In this
case, disconnect the USB device then reset this
unit and the USB device.
• Operation and power supply may not work as
intended for some USB devices.
• Do not leave a USB device in the car, or expose to
direct sunlight or high temperatures to prevent
deformation or damage to the device
Feb 12, 2016 | Kenwood Audio Players & Recorders
I cant install printer usb port is damage
Which USB port Damage because there are two USB port available.
One is Printer USB port or Sec is PC USB port.
If you are say PC USB port not working first you check it USB driver installed or not, or USB connect to motherboard or not. PC there are two side USB available one is front side and sec is back side. You connect only back side, because this USB connect to main board. So you connect only back side. If not working removed driver or installed driver.
Or if you are say printer USB then change cable or port or not solved only change option.
Read More Help.. If you have USB or Network Printer and are having trouble printing and HP Tech Support
Jun 27, 2014 | HP PSC 1315 All-In-One InkJet Printer
I have a new pc and the simple tech external hard drive will not show up even though the red and blue lights come on.
click start > right click on computer(or my computer) and click manage click on disk management and see if the 160gb drive is shown, if it is right click on it and click mark partition as active , if windows does not find a new disk then right click on the drive again and click change drive letter and paths. Choose a drive letter and click ok and your drive should now appear in windows. If it isnt showing in disk management then check that the drive is not beeping ,if it is then it is receiving insufficient power from the usb port try removing other usb devices to see if it will function correctly, once you remove the other usb devices you will need to unplug and reinsert the usb lead of the hard drive
Mar 19, 2011 | SimpleTech SimpleDrive 160 GB External USB...
Apple USB Ethernet suddenly not functional with mac book air
I've run into a similar problem myself. The problem could be that there is another device in the area using the same frequency and is causing interference. Try changing the frequency on your adapter. If you've recently added a wireless device and you can't change the frequency on your adapter try changing the frequency on the new device or turning it off to test if it's the problem.
It's possible someone else in the area has added a device that's causing the problem look around for new wireless devices or antenna in the area.
May 27, 2010 | Apple USB 2.0 Ethernet Adapter for MacBook...
I can't use any USB, it needs a registration on my laptop.. but i don't know how.. help pls!
If you can't use any usb device, the usb function is disabled.
  • To enable the usb function you have to access the Bios setup of your Desktop.
  • By pressing Delete button, F2/F11 button or Esc button in order to open the Bios Settings.
  • During power on the button menu will show up (press the key right away before the Windows starts)
  • In Bios setup there are several menu. Check each of them until you found the settings for Usb Functions
  • If the Usb Functions is disable change it to enable
  • Then go to the Save Menu and Save to apply the settings you created. (Sometimes F10 button is use to save the settings)
  • Restart the computer
To check if the Usb Function is working in windows mode open:
Start Menu > Control Panel > System > Hardware tab > click Device Manager.
Under Device Manager
click the ( + ) sign in Universal Seria Bus Controller
You'll see all the Usb devices detected in your computer
Jan 14, 2010 | Computers & Internet
Usb on packard bell function slow (type usb 1.0)
This is normal. USB 1.0 is a lot slower than USB 2.0...why are you using USB 1.0 on a system that has Vista x64? Is it because of the device? Change the device...
Jan 12, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
IBM THINK PAD 390X LAP TOP INVALID SYSTEM DISK
check that you have no floppy disks in the drive and also no usb memory sticks/Hard drives plugged in as if they are and are not bootable you will get the error you describe
Dec 11, 2008 | IBM ThinkPad T40 2373 Notebook
HOW TO FORMAT A WRITE PROTECT USB DRIVE
the drive isnt write protected the usbport or the connection is loose so that the computer is showing the drive as read only drive also you can format it using command and also setting off the read only attribute that may have been put by a virus also softwares like usbcillin makes pen drive writeprotected take care
Aug 26, 2008 | Transcend (TS40GSJ25) 40 GB Hard Drive
Car Audio & Video Logo
125 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
