Question about Cell Phones
How to reset plasma tv
Need to reset tv color
50" plasma panasonic 720p tv has several colored
Flashing error codes could be the Direct tv box itself.Because tvs have problems within itself don't flashes error codes on the tv screen,the problems,just show up.Tries tv and Direct tv satellite box unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting and the Direct tv box updates it softwares data's.The problems should be solved,if have the same problems,first call Direct tv for a replacement box,see how it work out.Than turn ur attention to the tv.
Feb 08, 2011 | Panasonic TC-P50X1 50 in. Plasma HDTV
I have a Panasonic 37 inch Plasma Viera 37PX50U The color has suddenly turned to all green and purple. Would like to reset factory color settings.
Hi dennisreno,
You should be able to set the tv back to factory default settings from the menu.
I will see if I can find the user manual and give exact directions.
Let me know if you find the reset.
Lone99star
Jan 29, 2009 | Panasonic TH-37PX50U 37 in. HD-Ready...
Panasonic TH-50PX60U Plasma TV no red color
I had the exact same problem. Thought it was the tv, but it was the cable between my cable box and the tv. Try unplugging the cords and plugging them back in, color was restored.
Oct 12, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Plasma tv screen has green pixelating into pictures
I had the same problem and solved it with a factory reset. hold menu button dowm for 10 seconds and it will alow you to reset all the colors.
Feb 01, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Hp Pe4240n 42' plasma tv
Here's the number to HP case management 877-917-4380 ext.79, try this number and be firm that they need to fix this, I just had an HP plasma that was 3 yrs old replaced for free, no charge. Good luck
Oct 28, 2007 | HP PE4240N 42 in. HD-Ready Plasma...
Plasma TV
Try to reset the TV to factory defaults and see if that helps. Record your color settings and any other setting your have in your config before dong this because all will be lost.
Jul 14, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Plasma TV problem - My Plasma tv is having a serious problem. Suddenly the Red color is no longer Red but Orange. The picture looks much worse now. I know it may sound like the set was getting old but I...
Try checking the cable making sure they are tightly plugged in. My dads Plasma screen started showing orange / brown colors in place of primary red... he had been moving things around and didnt realize the wires were loosened in the process. This made him realize.... GET an HDMI and get rid of all the other cables......
May 07, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
