Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Grease spots clothing - Whirlpool Cabrio WTW6600SBT Top Load Washer
2 Suggested Answers
jmeredith
  • 417 Answers
SOURCE: grease spots on clothes
That could mean your overloading your dryer to the point the wheel bearings are squished really bad. When loading your washing machine you should always be able to see the water level more than the clothes, your clothes should be floating in the water. That way, when you unload your washing machine and go to dry, you will have the right amount of clothes everytime
J
Posted on Jul 11, 2008
Kenmore 70 grease spots
If your starting to see black grease or oil spots on your clothes after washing and it seems to happen more and more chances are the transmission seal is busted and either the whole transmission or just the seal needs replacing.
Apr 24, 2012 | Kenmore Washing Machines
Grease /oil spots on clothes coming from washer
This sounds like the drum bearings are starting to wear and allowing grease to infiltrate through the inner seal.Does it sound noisy on the spin cycle.
May 03, 2010 | Speed Queen AWN432 Washer
I get oil/grease spots on my laundry ffrom my
You probably have a bad seal on the back of the drum, as that bearing is the only source of grease near your clothes. Good luck.
Jan 03, 2010 | Frigidaire GLTF1670A Front Load Washer
Greasy looking spots on clothing after washing/drying.
Without seeing the spots, this is a bit speculative, but here goes,......
I'm guessing that the spots are only found on the front side, primarily of shirts, or blouses, etc. These are from grease splatters from cooking, which many times only show up after washing and drying.
The soap releases some dirt, which is attracted to the non-removed grease spot, allowing it to show up. Re-wash the clothing, pre-spotting those areas with a citrus pre-spotter.
Aug 31, 2009 | LG WM0642H
Brown spots on clothes
Brown spots indicates a bearing is breaking up, the spots are the grease from the bearing and as the seal breaks down due to the bearings going off centre, the grease gets in the drum.
Get the bearings replaced if affordable.
Jul 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Grease-like stains on clothing
hi. i can help. the grease is coming from one of two places. Either some item with grease on it got placed in the machine and the grease transferred to the tub where it will cause the problem until it is spotted and removed with a degreaser, or wears off.
OR the grease is coming from the washer itself. Perhaps some grease oozed out of the mechanicals related to the aggitator.
Either way I would get a strong flash light or trouble light and look carefully in the tub and around the aggitator for grease. Then remove it with a cloth and some degreaser, available at any auto parts store.
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Spots on my clothes
hi, your drum bearing needs replacing, hope this helps, thanks for using fixya
Feb 15, 2009 | Kenmore Elite 45986 Front Load Washer
Grease spots on clothes
J
Jun 29, 2008 | Whirlpool LER5636P Electric Dryer
Your drum support bracket grease shaft seal (which will require a new Lip Seal Kit #12002022) is dead and potentialy the two shaft bearing are at risk. Parts cost retail approx. $100 or so. Labor, Lookout...
I'm fighting this issue for the second time.......
Bill B.
May 20, 2008 | Maytag Neptune MAH7500WH Front Load Washer
SPOTS ON WHITE CLOTHES
if your washer has a slight rumble noise when on the spin then it is most likely that your bearings are on there way out,what it is is the bearings have grease in them and once the bearings start to go this grease starts to leak into the drum which is what the brown spots are it also leaks at the back around the bearing at the back of your outer drum and also leaks onto the floor this will need fixing by a domestic appliance engineer but it is sometimes cheaper to replace the washing machine
Oct 17, 2007 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
10 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
