W10130987a screen removal dishwasher whirlpool
Dishwasher is not cleaning, is there a diagram available to inspect/replace filter, check water pump, etc.
Take the dish rack out. look at the back bottom of the dishwasher. you will most likely see a screen. Check if there is food, or a toothpick or a thin sheet of plastic wrap covering the screen. Remove it. Clean the screen and bottom of the dishwasher of any debris. Put the rack back in. Load the dishwasher, put in the soap and turn it on. You should have nice clean dishes.
Aug 26, 2015 | Whirlpool Dishwashers
Why is my Whirlpool dishwasher (GU1500XTLS) making a loug noise during a drain, wash and rinse cycle?
Could be a bearing, but it could also mean something ggt past the intake screen at the bottom and was pulled into the impeller. Turn off the power, remove the screen and inspect the impeller intake for any obstruction and remove it.
Aug 24, 2014 | Whirlpool 24 in. GU1500XTLS Stainless...
My whirlpool dishwasher will not get the top shelf dishes clean, it has a spray arm on top. any suggestions?
the sump has a screen inside that will often clog and cause this issue, remove the screen and clean it out.
Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have a whirlpool GU2700XTSQ1 dishwasher. I have the typical top rack not cleaning problem. I have removed the rear washer tube that leads to the top sprayer, no clogs. Upper arm is clear, lower arm is...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Sep 01, 2010 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Whirlpool dishwasher chopper blade
you can replac the chopper as a seperate part, but will quickly clog, and destry ohter parts of the unit if removed. dont take this the wrong way but if you have a garbage disposer already rinse the dishes better to avaid further clogging of chopper
Mar 31, 2009 | Dishwashers
Whirlpool Dishwasher Model GU1200XT
Check the upper spray arm for debris plugging the spray holes, if clean then pull off lower spray arm and filter screen, and clean and remove any debris found in the sump, check the disposal blades as well. You will need a torx style screwdriver to remove the sump screen on this unit. You can buy a set for under $10 at your local hardware store.
Feb 22, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Not getting enough water
you would need to remove the inlet water valve, the screen is just past your installation point
Nov 06, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet wash plus
I assume you are having spray issues, or a grinding noise. If odor is your issue, go to the bottom of the message.
For the dishwasher pictured above, Open the door. Remove the lower rack.
Push in the tabs holding the upper basket rail end caps and slide the caps up and out. Remove the upper rack. Clean the holes in the upper (or middle) spray arm.
Hold the lower spray arm still and rotote the thumb tab clockwise. Remove the lower spray arm. Clean the holes in the lower spray arm.
Use a small flat screwdriver to release the tabs holding the upper spray tube from the dishwasher inner wall and ceiling. Rotate the spray tube to the right and remove the tube.
Using a # 20 Torx bit, remove the (about 10) small screws holding in the top of the sump assembly. Remove the top section with the fingers all around it.
Using a # 15 Torx bit, remove the screw holding the round cover over the pump suction. Remove the cover (grab the tab sticking off the corner with a pliers and pull up.)
Anything stuck in the sump will now be visible. If the screen is completely clogged up, then the blade isn't wiping the screen clean. In this case, the screen should be replaced.
The screen is removable, but difficult to re-install. If you need to re-place it, put an open end wrench between the screen and the rotating blade to hold the spring compressed. Also, notice the screen isn't round. The flat edges fit only in the slots they came from.
If it's odor or white powder you want to clean out, use a dishwasher cleaning product such as Dishwasher Magic.
I tell every dishwasher customer: "You do not need to rinse your dishes before washing. But you do need to scrape them off."
Mar 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
WHIRLPOOL MODEL DUL300 GRINDING NOISE
You might have something bouncing around in the wash pump inlet in front of the "chopper". Remove the lower arm and upper arm supply tube. Remove the screws then remove the screen, accumulator and inlet protector. You should see debris in front of the screen. 0ca22aa.jpg
Dec 28, 2007 | Whirlpool DUL300 XTL Built-in Dishwasher
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
