Question about Water Filters & Coolers
What causes water to freeze - Water Filters & Coolers
The freezer part is leaking inside from the grills at the back. Which is freezing into blocks behind the grills
are u sure its a water leak and not just a bad defrost terminator problem freezing everything, or a bad heating element causing freezing? the only other thing that will cause water leak is if u have ice maker with a bad hose seeping water out?
Jun 09, 2015 | Refrigerators
What causes a water cooler to freeze up around coils?
It is dues to improper air flow. which can be caused by multiple factors.
1. Return Air Vent is blocked
2. Evaporator Fan not working
3. Improper Thermostat.
Is the water cooling Ok. if the thermostat is not ok, the water might be really freezing.
Nov 05, 2014 | Water Filters & Coolers
Water in oil
Water in oil is usually caused by a cracked engine block. This is a serious problem which could have been caused by the water freezing inside the engine. Water freezing in the engine could be caused by insufficient anti-freeze in the water. Of course the other possible cause of finding water in the oil could be by a defect in the metal structure of the engine block. Either way....that indication usually points to a worthless engine.
Mar 20, 2014 | 1993 Chevrolet Cavalier
Maytag model MSD2754FR - water tube to ice maker is freezing and causing water leakage and no ice cubes.
The reason that tube is frozen is because the water inlet valve is defective and not fully closing yet staying open a little and water is seeping through that tube and freezeing...its only a small drop but soon th enext drop freezes as well then before long a buch of little drops freezes resulting in the tube totally freezing. Replacing the water inlet valve will prevent the seeping thats the cause of it freezing up, the part number for that valve is 61005626 it could be purchased at your local appliance partstore or online at;
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
partselect.com
GENE
Oct 02, 2011 | Maytag Refrigerators
2004 Neon was overheating... replaced thermostat, relay switch, heater core, and when antifreeze was put in, in stopped overheating... what could be the problem?
Water only or very little antifreeze can cause the radiator to freeze and restrict the flow of water in the engine block causing the engine to everheat.Not unusual to see this time of year when the temperature gets below freezing.Even though the temp may only be about freezing , when the air starts moving through the radiator when driving it creats a wind chill factor and can freeze the water in radiator.Always keep a 50/50 mixture in the coolant system.
Feb 06, 2011 | 2003 Dodge Neon
Why do the freeze plug keeps popping out and keeps over heating change t stat and water pump
If your in sub bellow zero weather you need to install engine anti freeze not water this is the cause of freeze plugs popping water in your cooling system if you install anti freeze this should stop these from popping out on =you.
Jan 09, 2011 | 2001 Volkswagen Beetle
Water is freezing in the tube feeding into the ice maker. What could be the cause?
Generally the cause is a defective water valve that feeds the icemaker.
The water valve is allowing a small amount of water to leak past the seat. The water then slowly drips down the icemaker fill tube and freezes in the tube causing a blockage of ice to fill the diameter of the fill tube.
Replace the water valve.
Clean or replace the water supply valve that supplies the house water to the water valve on the ref.
This will ensure trouble free ice maker operation.
Jan 16, 2010 | Refrigerators
Water does not flow through the dispenser
sounds like the sensors are playing up causing the bottom of the fridge to freeze, this will also cause the water reservior to freeze thus no water to the ice tray and water dispensor. do a full defrost then see if you gain back all the functions proving the sensor fault.
Apr 05, 2009 | Frigidaire FRS26R4A Side by Side...
Freezing food and leaking water
faulty water valve will cause the issues with the ice maker fill tube , possible faulty air damper will cause the fridge to get too cold
Jan 07, 2008 | GE PSS25NGM Side by Side Refrigerator
Kenmore / GE side by side defrost drain keeps freezing up
Check under the base, the tube must be clear to the water tray, often there is a rubber flow restrictor, this either perishes or blockes, either way remove it, defrost over night and then turn back on, should then work ok within 24hrs. Regards Adbvisor
Aug 15, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water Filters & Coolers Logo
65 people viewed this question
Top Water Filters & Coolers Experts
John Tripp
John Tripp
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
