Question about Soundstream H-305BAR SLIM-TYPE SOUNDBAR WITH WIRELESS LOW-PROFILE SUBWOOFER
Remote code for model H-320bar
Need code to set up with direct tv
Need the code list for quantum view model QTC32A7F to set remotes
I found a perfect fix for the 32 inch Quantum View TVs with a DirecTV remote.
Press Menu (on your directv remote) , go to settings/help>Settings>RemoteControl>Program Remote>TV.
When prompted to choose a brand, select CURTIS MATHIS. The codes from Curtis Mathis should match the codes for your Quantum View TV.
Note: Make sure the remote can 'see' the receiver during this process.
Sep 09, 2012 | Televison & Video
Remote program code for model DP26649
search google for tv remote control codes
Nov 16, 2009 | Televison & Video
Programmin my remote
Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 You could try the one below..
I know the new HD boxes and DVR HD Boxes have the new remotes and they included Olevia on it and it works with the new models of Olevia's
Jul 15, 2009 | Olevia LT32HVM 32 in. LCD Television
Need codes for olevia tv
Olevia TV Remote Control Codes #tbltrouble TD { BORDER-BOTTOM: #cccccc 1px dotted; PADDING-LEFT: 2px }
Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for all 2 Series, 3 Series, 4 Series, 5 Series, and 7 Series Olevia HDTVs.
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, Tivo's, DVD, Blue-Ray™ or even HD- DVD players.
The learning remote is available, please call at 866-965-3842
Satellite TV Systems Dish Network Remote Codes 506 or 127 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Cable TV Systems Cable Vision Remote Codes 506 Charter (Moxie Box) Remote Codes 1144 or 1178 Comcast Remote Codes 11144, 11240, 11331, 21075, 10159, 10154, or 10088 Cox (Remote Model UEI M720p01) Remote Codes 1610 Brighthouse (Remote “UEI” URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote “UEI” URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote "UEI" UR5L-8500L) Remote Code 432 Time Warner (Atlas OCAP 5) Remote Code 1610
Jun 21, 2009 | Olevia LT27HVX 27 in. LCD Television
I have a new RCR312W TV remote. I have lost directions
Someone had posted a solution to manually program the remote. The information came from RCA website. It worked fine. I still would like the code numbers for my remote. I have a LG TV that is about a year old.
Feb 14, 2009 | RCA Universal Remote Control
Remote codes
Contact Direct tv and they should have the codes to program the remote tothat tv. Or contact Universal remote @ 919-573-7854 919-573-7854
Aug 17, 2008 | Philips Magnavox Learning Universal Remote
I need a remote code for a hitachi tv
Here is the setup copde page http://universal.dev.efocus.nl/?pag=54. I didn't see that model remote listed but many times the remote manufacturer will use the same codes.... So look at other remote codes for Hitachi and see which one works.
MM85
Jul 24, 2008 | One For All URC-3021 Remote Control
Remote control code list
The Konig IR9982 is not a universal remote control so there is no code to make it work your Bush TV. It is actually a direct replacement (electronic clone) remote for some Hitachi models.
You will need a direct replacement for your particular model, try http://www.remotesreplaced.co.uk/television/remote-control-bush.htm
Feb 19, 2008 | Universal Remote Control DIRECTV Universal...
I NEED THE CODE FOR ALBA TV MODEL NO. ALCD15TV8M
There are two code types for sky remotes, Brand Codes & Direct Codes.
The codes for Alba are:
Brand - 0043
Direct - 037, 065, 246, 399, 263, 064, 446
There is a small difference in the way they are set.
To program using the 3 digit code - Direct Code
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Enter the 3 digit code
5) Press the select button to store
Press TV and any number to test, If this does not operate the TV set try below.
To program using the 4 digit code - Brand Code
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Feb 18, 2008 | Televison & Video
Soundstream H-305BAR SLIM-TYPE SOUNDBAR WITH WIRELESS LOW-PROFILE SUBWOOFER Logo
24 people viewed this question
Top Soundstream Televison & Video Experts
Brett Duxbury
Brett Duxbury
ELECTREPAIR USA
ELECTREPAIR USA
Are you a Soundstream Televison and Video Expert? Answer questions, earn points and help others
