Question about EliteGroup P6VXAT Motherboard
Wont boot and no signal to the monitor
The computer is working, the fan is working but it wont boot and no signal to the monitor,just black..
  • jmichael_zar May 21, 2009
    thanks..i will do that..
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    unseat and reseat the ram one stick at a time in each slot one at a time and check for video each time.
    Also unseat and reseat the CPU.
    Problem Solver:
  • 8 Answers
Try running it without any ram in, as bad ram could cause that. Also you may have shorted your motherboard. It sounds stupid, but did you remember to put your standoffs on?
Posted on May 21, 2009
Computer is not booting to windows
Reseat the ram. If that doesn't work, try reseating whatever you can --without shorting out the chips. Follow proper procedure for not frying your setup with static electricity while you do this.
Here is a link offering the possible fix and/or some company in similar situations.
Computer fans turn on but nothing else
Sep 18, 2017 | Computers & Internet
My Monitor keeps going black
Sounds like you have something overheating in the screen pull the back cover and blow it out.
Jan 20, 2013 | HP 17 1740 DVI Rotating LCD Monitor w/USB...
Asus crosshair socket am2 motherboard not booting
Sounds like your monitor is bad. Try another monitor because if the video card was bad and the monitor is working you would get a No Signal message on the screen. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your original monitor is bad. If the Borrowed monitor does the same as your original monitor and does not display anything, then there is an issue with your video card.
May 13, 2012 | Computers & Internet
My computer works normaly with an single core athlon 3200+ but when I use an Athlon 4400+ or 4000+ dual core, it just wont boot. The fans are running and lights are on but there is no signal on the monitor...
take a look at the motherboard manufacturers website and see if your motherboard will accept a 4400. You may need to update the bios on your board to accept the faster processor. You need to be careful if you flash the bios. do it wrong and you can write the board off.
Good luck
Aug 11, 2011 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
Screen not responding
can you hear any boot sounds?
(fan noise, harddisk rattling)
do the LEDs work (battery and charger , Hdd, CD/DVD-ROM-drive,WLAN)?
this would indicate it still boots up, but screen might be broke.
u lucky?
- remove battery pack! retry booting
if not, hook it up to another external monitor
(use vga-jack in the back of it)
reboot, wait for signal
- check if the the fan is jammed
(due to sand???)
this might cause overheat problem -
use compressed air to blow/clean the fan inlet
still no luck? it simply may be broke...
Aug 04, 2009 | Computers & Internet
Gateway FPD1760TFT LCD monitor
Problem
1. turn on computer
2. monitor receives signal, it looks like its working
3. it goes through some steps and then the monitor says "no signal" and kind of stays in limbo with fans running, etc.
Solution
One possibility is that computer is looking for drivers for you video card. It could be hung up looking in the wrong places. Remove all peripheral hard drives and memory sticks. Try again.
Jan 12, 2009 | Gateway FPD1760 17" LCD Monitor
Hanns g JC199D will not turn on, comp is on, try to turn monitor
no signal indicates a couple things... i suspect your computer isn't even booting up. reboot the computer while tapping the F8 key.... you should see writing on the screen... boot to safe mode. after it sucessfully boots up... reboot again... should be fine.
Robert
also is that an add on video card ?
Dec 18, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Computer randomly fails to boot
how many video cards do you have installed?
Nov 14, 2008 | E-Machines eMachines Desktop PC
EliteGroup P6VXAT Motherboard Logo
140 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
