Question about Hunter 21894 Westover Four Seasons 52-inch 3-Speed Ceiling Fan with built-in Heater & Light, 5 Blades, Remote Control, in New Bronze Finish with Walnut and Cherry Blades
Light will turn on but will slowly go off - Hunter 21894 Westover Four Seasons 52-inch 3-Speed Ceiling Fan with built-in Heater & Light, 5 Blades, Remote Control, in New Bronze Finish with Walnut and Cherry Blades
Tip
How to reset the machine
Reset Procedure for Equator / Hirundo ( EZ3612CEE / EZ2512CEE / EZ1612V )
If the door of the machine is opening you can follow the below reset procedure so that the machine will function properly but if the door in your machine is not opening you need to first get the door to open by following the procedure as stated in the link http://www.fixya.com/support/r4240518-door_not_opening_in_equator_hirundo
Resting the unit will make sure that all the memory storage in the chip will be erased and hence the unit will be ready for a new cycle.
Reset Procedure
  1. Make sure that the machine is turned OFF.
  2. Make sure that the door is opening.
  3. Set the dryer & wash temperature knobs to the off position (12 o'clock / pointing vertically upwards)
  4. Make sure that the door is latched properly.
  5. Set the washer knob on the Red Reset position and switch on the power.
  6. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  7. Once the light starts flickering slowly turn off the power.
  8. Set the washer knob to the Green Reset Position and switch on the power.
  9. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  10. Once the light starts flickering slowly turn off the power.
  11. Set the washer knob to the Grey Reset Position and switch on the power.
  12. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  13. Once the light starts flickering slowly turn off the power.
  14. Set the washer knob to the Reset Position on Delay Time and switch on the power.
  15. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  16. Once the light starts flickering slowly turn off the power.
You have now reseted the unit and the unit should work fine now , in case you observe that the washer knob/Dial is going round and round all by itself now please go through the link for fault codes for further diagnosis.
Hope this procedure helps.
on Mar 02, 2010 | Washing Machines
Fan turns very slowly with remote
If there is a pull chain on the fan, make sure it is on the high setting. Also you could check the capacitor to make sure it's not going bad. Otherwise you could need a new receiver.
Dec 02, 2015 | Dryers
When I turn power on my acer aspire netbook the screen is black. The only light that lights up is the battery light. Do you know what is the problem and how can I fix it?
Have you tried turning it on using your adapter? If there is still no power light, try removing the power jack in the laptop and the power cable in the adapter and re-insert it both then plug it then test it again. If there is still no power light, try bending slowly the power jack cable in the laptop while inserted and slowly bend and move until you reach the power adapter. Observe the power light while bending the cable. If the light turns on while bending, the wire/s on the cable might be cut where you bend and see the power light turning on. If there's still no power light, your power adapter or the laptops power supply might be defective.
Sep 25, 2011 | Acer Aspire One Netbook 8.9" Notebook
Bought new hose, attached to grill and new bottle of gas, burners wont light.
Turn the grill tank valve OFF. Disconnect the hose from the tank. Wait 5 Minutes and reconnect the hose to the tank. But, this time, open the tank valve VERY, VERY, SLOWLY (Slow motion. slow) Until the valve is fully open. Light the burner farthest from the tank first and turn it to HIGH. Did the burner light and does the flame height look correct? If so, light the remaining burners the same way. Did all the burners light and do the flame heights look correct? If so, you solved the problem (with a little help). Remember to always open the tank valve very, very, slowly.
Happy Grilling!!
Jun 23, 2011 | Char-Broil Grilling
New webber will not start
Ok, let's tackle the obvious things first. New grill with new tank... so was the tank filled? Did they purge it before they filled it? Did you turn the tank valve on very slowly? Were all the grill knobs turned to off when you turned on the gas tank? Try closing the propane tank valve, disconnecting it and reconnecting it. Then very slowly turn it on and light one burner at a time at turn to low heat. Then light additional burners the same way and adjust flame as needed after all are lit. Hope this helps! Douglas
Jun 06, 2010 | Weber Summit S-470 Propane Grill
My didgital frame will not turn on. ADS-18H-4 0918G
My didgital fram will not turn on. ADS-18H-4 0918G switching adapter does have a slowly pulsing green light. But will not turn on the picture frame. Where can I get a replacement or how do i get it to work
Mar 22, 2010 | SmartParts SP15MW (092566981886) Digital...
GE Spectra TrueTemp Oven Pilot is Out
REmove bottom panel from stove. shut gas off for at LEAST 5 min. Longer is better. Then placel open flame above gas nozzle, slowly turn to ignite posiiton. After it is lit, wait 30 seconds and turn to on positon.
If by chance this model doens't have a knob for this, then turn gas valve off for 5 min, let fumes evaporate, light flame, place over nozzle, turn gas on.replace bottom oven panel slowly.
Jan 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Hunter 21894 Westover Four Seasons 52-inch 3-Speed Ceiling Fan with built-in Heater & Light, 5 Blades, Remote Control, in New Bronze Finish with Walnut and Cherry Blades Logo
Top Hunter Televison & Video Experts
pblo
Level 1 Expert
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
