The Infinity Comfort Control code
The Infinity Comfort Control that comes with the installation of our new Infinity Carrier airconditioning unit can be used as a troubleshooting device. How can I get the code to enter into the troubleshooting mode?
  • 614 Answers
Call your local Carrier dealer. They have code to get into system. Rusty Good system
Posted on Jun 04, 2009
What could cause carrier fault code 42 besides bad inducer
Could be several causes.
1. Blockage on piping
2. Water in inducer housing slowing down inducer impeller
3. Condensate trap for furnace clogged up.
4. Inducer motor going bad.
5. Leak in vacuum hoses or not connected.
Welcome To the Best HVAC
Oct 09, 2014 | Carrier Comfort 13 Series 1.5 ton 14.5...
CARRIER INFINITY WEATHERMAKER WHERE IS THE RESTART SWITCH
Carrier Infinity systems, do not have a manual reset switch. It will have an automatic reset depending on the failure.
I would first, turn off the breaker to the indoor and outdoor units. Wait about 5 mins and turn the breakers back on. Doing this will reset the Control Board in the system. The system itself, is probably locked out.
This should get the system to come back on, However, you may have the problem come back and lock out the system again.
If this happens again, i would advise calling a Carrier dealer with Infinity systems to test it.
Hope this helps
Brian
Nov 28, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier infinity control SYSTXCCUID01-B sensor communication erro
There should be a little black sensor bulb outside either on the unit normally under the electrical panel or inside it. It sound like the wire has come off or been disconected. It needs that on to properly run. Your control is trying to communicate with the outdoor unit and can not.
Jul 07, 2009 | Heating & Cooling
Shopping for a new AC. Looking at Carrier Comfort
For the money might want to look at a ruud or reem carrier is just kind of higher in price and the warranty every manufacture carries at least 5 years on the compressor hope that helps shop around do your home work and remember any unit is junk if not properly in stalled. good luck Tom
Jul 06, 2009 | Carrier 38CKC036 Air Conditioner
3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Jan 04, 2009 | Carrier 52CQ-312-4 Comfort Series Heat...
Carrier Air Conditioner Infinity System - Air Handler Sweating & Duct Work Condensation
Either its not drainning mositure properly or low air flow across the "A" coils- caused by dirty filter .
Sep 12, 2008 | Heating & Cooling
Carrier Infinity DC motor drive problems
Contact the company that installed the unit. Its new, under warranty, Anything you do could void the warranty. If they do not take care of the problem without charges contact Carrier and tell them what's going on. The company who installed the unit is responsible for making it run correctly. Good luck. kstfas
Aug 26, 2007 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
501 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
