Question about Weiser Lock GED1460X GED1460X11P Venetian Bronze PowerBolt Powerbolt Touchp
Weiser batteries How do I change the batteries in my Weser lock?
5 Suggested Answers
SOURCE: Changed the batteries but the Weiser keypad lock
Mine did that too for a month. Make sure all the batteries are new alkaline batteries of the same brand, and remove them for a few minutes (if already installed) and replace them in the unit. I reset my code as well afterword. Did the trick for me.
Posted on Oct 06, 2010
  • 15 Answers
SOURCE: Weiser powerbolt worked well for
Hi... You have too be sure that the deadbolt is free when it go inside the deadbolt hole... however this system is very low power and the (over torque clutch) will sleep if the deadbolt it's not completely free.
Also if you try to open the door before you unlock it, you may block the the deadbolt inside the deadbolt hole. Take care too unlock the door before open-it...
Good lock or good unlock
Posted on May 15, 2011
  • 15 Answers
SOURCE: Weiser combination lock beeps
You should check if the keyboard ribbon cable is properly connected and not pinched or cut ... Also it is possible that water has entered into the keyboard. In case you should remove and dry with a hair dryer.
  • 963 Answers
SOURCE: my Weiser powerbolt lock is beeping-changed batteries-won't stop
Why is my Powerbolt 1000 unit beeping?
To determine why your lock is beeping abnormally, please follow these steps:
  1. Take out batteries and unplug powerstrip.
  2. Let it sit for 1 minute, then put the batteries back in and wait another minute.
  3. If it does not beep, the keypad needs to be replaced (17733-1).
  4. If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
Contact Customer service from here:
http://www.weiserlock.com/CustomerService/ProductSupport/SupportContact.aspx
Posted on Feb 23, 2012
How do I enter new code?
[PDF]Quick Reference Installation & Programming Manual
www.weiserlock.com/.../electronics/smart...
Translate this page Weiser Lock25605-02 Weiser SmartCode Manual. Program. Button .... Press and hold the "LOCK" button on the exterior keypad, while fully inserting the battery pack into .... anyone withaccess to the power board can change these codes, you must restrict access ...technical means, or evaded by entry elsewhere on the property. No lock.
Nov 26, 2015 | Weiser Lock Locks & Locksmithing
Change batteries in weiser Powerbolt elec deadbolt
Pull the inside cover away from the door, to remove. This exposes the battery holder. Replace all four AA batteries with new alkaline AAs The cover snaps on. Align top first.
http://www.weiserlock.com/PDFs/instructions/Electronics/Powerbolt.pdf
Mar 31, 2014 | Weiser Lock POWERBOLT ELEC DEADBOLT
Lost combination
The Weiser brand and Kwikset brand Powerbolt are identical, so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Change the batteries with fresh brand-name batteries before you reprogram!
Sep 21, 2012 | Weiser Lock Powerbolt 1000 Lock
My Weiser powerbolt lock is beeping-changed batteries-won't stop
Jan 09, 2012 | Weiser Lock Powerbolt 1000 Lock
Changed batteries but still doesn't work why?
Since you've already gone through the battery change, this suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense. Secondly, your lock may be new enough for you to talk them into warrantying it, and thirdly, they will be able to get the correct part on order for you.
Jul 18, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
I have a weiser combination lock and it seems to be bogging when keying the comb. in so i recharged my batteries and installed back into the lock and it still bogs. Is there one batterie better than...
Weiser has a lifetime warranty against mechanical and finish problems with their locks. Contact them from this link:
http://www.weiserlock.com/en/Products/SmartSeries/Powerbolt.aspx
Jun 28, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
Changed the batteries but the Weiser keypad lock keeps beeping
Aug 23, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Jul 09, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
I have an old weiser powerbolt 3000 with a remote. my battery went dead in the remote and i lost it after removing it. can anyone tell me what battery the remote takes?
I have the Weiser Lock powerbolt 3000 Home Access system Model WLTX Garage door opener and the Battery is a Maxell CR2032 3 Volt. very common.
Nov 18, 2009 | Weiser Lock Locks & Locksmithing
Weiser Lock GED1460X  GED1460X11P Venetian Bronze PowerBolt Powerbolt Touchp Logo
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
