Question about Exercise & Fitness
Hebb industries treadmill - Exercise & Fitness
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: I have a Powertred 7.0 Softrak treadmill made by Hebb Industries. The LED Readouts for speed, distance and time will only read 000.Pressing the reset key does nothing. Any suggestions on how to fix
adjust the Reed switch see the diagram attached, clean it, and tigh the plug very well.
2) tight the ribbon inside for keypad, and clean it.
3)tight the connector from display board vs lower board.
4) Run finally the software calibration for diagnostic, troubleshooting and fix it.
God bless you
Posted on Sep 21, 2012
I would like to know if there is a manual available for the Power Tred 3250 treadmill by HEBB Industries?
Let's try Googling (Power Tred)(3250)(manual) without parens. Maybe something good will happen.
Dec 13, 2016 | Exercise & Fitness
It's over heating, have lubed the belt, taken the cover off and put cold air through the motor. at a loss as to how to fix this.
Most likely the vents on the motor are blocked with dust, etc. Turn off the power and have a good look at the motor. You may need to disassemble it to clean it properly. It may or may not fix the issue, if its really bad the bearings could be seizing up. You can tell that by testing when you have it apart. You may be able to replace the bearings for only a few bucks. If you need to replace them take them off intact if possible and take them to a local industrial supply outlet, they can usually match them up for you.
Mar 19, 2015 | Horizon CT 5.0 Treadmill Walking Belt
My treadmill got rained on last night and when I plug it in it turns straight on to 11mph even with the safety plug pulled out. Could it possibly go back to normal when it dries out?
Very possible. Suggest you take the electronics apart to help it dry out. Use pressurized dry air to blow water out. I would not just let it sit with the covers on.
Mar 12, 2015 | Exercise & Fitness
Spirit treadmill st200
That machine is way too old to put any money into it. The fix for that particular problem is to replace the deck and belt.
Oct 21, 2017 | Exercise & Fitness
Motor gets Hot
I'm not familiar with the treadmill specifically, but here is some general information that might be helpful. When a motor is under heavier load, it draws more current and therefore gets hotter. If for example, you were able to stop the motor shaft from rotating with an extreme load, it would draw what is called STALL CURRENT which is very high. So the problem seems to be that the load is out of specification. I'm assuming it would probably get hot if it was running with nobody on it as well. That would mean that the drive mechanism driven by the motor is not moving freely. If you can somehow decouple the motor from the treadmill drive system so that it has no load, and then move the mechanism by hand to see if it feels like there is a lot of resistance in the belts, pulleys or whatever drives the treadmill, then you need to lubricate to make it move smoothly. Or if you cannot decouple the motor, just look for all the bearings and pulleys and lubricate those but be careful not to get oil on drive belts or surfaces that require friction such as the surface of the belts or treadmill band. Don't ignore that the motor could get hot enough to start a fire so it is important to resolve this. It is possible that there are shorted windings and the motor is no longer good. If you can decouple the motor and run it no load, and it still gets hot, that would be an indication of such a shorted winding problem. Hope this is a little helpful. G
Feb 07, 2014 | Spirit Esprit ET4 Treadmill
God bless you
Sep 21, 2012 | Exercise & Fitness
I need to find rubber belt for tread mill Dynafit executives series aprox. 15 years old. I believe its belt number KIH-260J
The only suggestion I have since this manufacturer has gone the way of the dinosaur, is by going to a local dealer that carries industrial belt of different sizes and and shapes you may get lucky and find something. I wish good hunting
May 17, 2010 | Exercise & Fitness
Looking to buy a good quality treadmill for home. Is the Tunturi T30 worth considering? I will mainly be power walking. The Lifefitness are very expensive...any other brands you recommend? I i live in...
Tunturi unit have been always a reliable unit and they do not have very many problems. I like and sell the Sports Art products for five years and they are reliable and sturdy units, at one time they were manufacturing for Tunturi and other highly visible companies in their 30 plus years in the industry.The only worry is, do you have a reliable service company that will take care of you if whatever product you choose to purchase. I know as a servicer I rely on my vendors to give me great service so I intern give great service to my customers.
May 10, 2010 | Tunturi T30 Treadmill
Sirs Ihavechanged from windows xp to Vista,on my new laptop but the driver is not compatable with vista can i download a driver that is ok . Noel H Hebbs
Yes just goto the manufacturer site and search driver for your model number.............and download......finally..:))
If any problem tel me your manufacturer and model no...
Thanks
Iqbal
Apr 06, 2008 | Office Equipment & Supplies
Exercise & Fitness Logo
88 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
