Question about Clarion DXZ655MP CD Player
Wiring harness for clairon radio modle dxz655mp
I need a wireing harness
thesoundman
  • 41 Answers
SOURCE: WIRING COLOR CODE
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Posted on Sep 21, 2007
simplemitch
  • 752 Answers
SOURCE: clarion db245 NEED WIRING HARNESS FOR CD PLAYER
it can be ordered from www.pacparts.com
Part number 854365900 for $15.89
Posted on Aug 05, 2008
rteemon
  • 578 Answers
SOURCE: wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Posted on Jun 25, 2009
messstat
  • 365 Answers
SOURCE: i have a clarion dxz655mp and i need the wiring
Wiring diagram for the internals...you're out of luck. Wiring for hooking it up in a car...Go to a car stereo shop and buy a wiring harness for your make/model of car ($25-35). or crutchfield.com
Good Luck
Posted on Jun 26, 2009
  • 122 Answers
SOURCE: I have a Clarion xmd3 radio that will not power
check to see if you have any grounding issues or if ground is present
Posted on Jun 12, 2010
Order of wires in harness for clarion Dxz655mp
Here is a color coded picture of the wiring.
Oct 17, 2016 | Clarion Car Audio & Video
I have a used kenwood modle kdc-2165. all the wires but no color codes. and i am putting it in a 1988 ford f150 custom, also i have the wire harness but no color codes. and i have a yahoo email...
If you are installing a radio, I recommend you purchase a wiring harness specific to the vehicle you are installing into. You can find them at places like www.crutchfield.com . If you are just looking for a wiring diagram to hardwire the radio, try www.mobileinformationlabs.com
Aug 29, 2011 | Car Audio & Video
I need a color coding of the wiring for the harness i was given for my kenwood dpx308u. i just need to know which colors belong to which wires
Ok, you should have a wiring harness that plugs into the radio. That comes with the radio. You will need a wiring harness that is specific to your vehicle, this will plug into the vehicle harness. The wiring harness will have the correct colors to attach your radio to it. All aftermarket radios have standardized wiring. I recommend not attempting to hardwire your radio due to the risk of frying your entire electrical system. I hope this helps.
Aug 19, 2011 | Car Audio & Video
My dxz665mp has two power wires (a 15 amp and a 3 amp) what are they for? I am new to installing and I lost the box and instructions.
Cd players require 3 wires for the unit to power on and thankfully name brand companies have made it easy for the consumer by making the wire harness with standardized wire colors. The wires that have the in-line fuse holders should be yellow and red.
The yellow wire is the constant 12 volt power feed to the the deck. This wire needs to have power all the time for the deck to maintain it's memory (ie saved radio station presets, audio settings, clock etc...).
The red wire is called the switched ignition or ACC (accessory) wire. This wire will only have power when the key is turned on.
The third wire all decks need is the black ground wire. All car electronics need power and ground to turn on.
The other wires are your speaker sets... white (+) and white with a black stripe (-) for the front left speaker, grey (+) and gray/black for front right, green (+) and green/black (-) for left rear and purple (+) and purple/black (-) for right rear.
Other wires...not all makes and/or models of radios have these but, if your's does, here's what they are.
blue with a white stripe - amp turn on wire, used for providing a turn on trigger to aftermarket amplifiers (some factory amplifiers too depending on the make, model and year of vehicle)
orange or orange with a white stripe - illumination wire
solid blue wire - power antenna wire, this makes motorized antennas go up and down when you turn the radio source on/off
Apr 02, 2011 | Clarion DXZ655MP CD Player
Need to no what the two yellow wires are for on the claion dxz655mp
Use this one. Not the same model, but close enough for government work: clarion.com/us/en/DXZ655MP%28Manual%29.
Also could check this install guide...
Hope helps.
Mar 15, 2011 | Clarion DRX5575
Need to know what wire colours r what on the harness of a Clarion DXZ635MP CD player lost manual
Your ground wire is going to be black. Your normal wire colors are violet and violet/black, green and green/black, white and white/black, last but not least you have grey and grey/black. Those are your speaker wires. Solid blue is usually to power your antenna, and blue/white is for your amp turn on lead. Those two wires are approximately .5mV of power, and you can actually use either one to turn an amp on. Speakers: normally your solid color is positive, while the black stripe is your negative. As for which one goes to which speaker, left front is white, right front is gray, left rear is green, and right rear is violet. Hope this helps.
May 27, 2010 | Clarion DXZ655MP CD Player
Clairon model number pu-2294b message on radio reads error 4 how do i clear this to reset thanks
clairon model number pu-2294b message on radio reads error 4 how do i clear this to reset thanks
Apr 23, 2010 | Clarion Car Audio & Video
I have a clarion dxz655mp and i need the wiring diagram for it
Good Luck
Jun 25, 2009 | Clarion DXZ645MP CD Player
I would like to know what harness & Kit i need to install radio
Metra is the only manufacture I use.
#70-1858 Wire Harness
#99-3101 (with A/C) #99-3102 (w/O A/C) Kit
Also a mini gm to standard antenna adapter is required.
#40-GM10
Jan 22, 2009 | 1989 Chevrolet Beretta
Clarion radio wiring diagram
i have the same stero in my boat made 2004 it is easy red(hot) black (Ground) Orange (Illumination) (hot) the 2 fused yellow is bat direct (memory) blue w/white stripe (remote) solid blue (power attenna) the 2 white wires ft left speaker, 2 gray rt front, green left rear, purple rt rear, the single brown is for the changer i believe
May 28, 2007 | Clarion DXZ645MP CD Player
Clarion DXZ655MP CD Player Logo
20 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
