When i turn on my central vac it has a high squeal
I have just moved into a new house and when I turn on my central vac it a really loud noise that everyone around me can hear. I have talked to others and they said it should not be that loud.
5 Suggested Answers
  • 4 Answers
SOURCE: Squealing noise during spin cycle
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
Posted on Jul 08, 2007
shaggyrat
  • 1224 Answers
SOURCE: kenmore 80 series washer
sounds like the joint coupler is broke from motor to drive simple 5 dollar item and about 1/2 hour labor to replace its a do it your self job easy to replace but heres another problem that i ran into before you got some material stuck in the water pump that could be the whole problem sometimes people pack washer above the tub then it goes into the water pump
i pulled out my girls sock out of the water pump easy fix tip up washer put something under washer so dont rock foward pull off hoses and then water pump look inside if theres something stuck in there use a pair of needle nose pliars to pull out easy then put back together
Posted on May 07, 2008
SOURCE: When the washer spins it
My new Samsung washer shakes so bad. I'm going to call samsung or take it back to sears soon.
Posted on Dec 27, 2008
SOURCE: My Admiral Capacity Plus Clothes Washer Ends Cycle with a Squeal
my problem with my washing machine is that it take long to drain out the water.
Posted on Jul 07, 2010
Cool air from home vents with central AC outdoor unit fan will not turn on. Inside home really loud when on!!
its look like blower problem , 1st check blower speed controller, check blower motor , check its ball bearing etc , its does not have any link to external unit .
Jun 15, 2014 | Goodman Heating & Cooling
Tps on nissan quest makes loud noise when accelerates
As I look at your letter, which is very good, I might add, here are the few things that occurred to me.
The "loud squealing" should be a belt.
You have one or several belts, and if they get loose, or are worn out ( that includes the belt rubber getting old and hard) they will squeal like that.
However, the squealing also may be coming from one of the pulleys the drive belt or belts are attempting to turn.
If you have a bad bearing in one of the pulleys, you can get that loud sound like " a train".
If you are really careful, a "mechanic's stethoscope" might help you.
That is to take a really long screwdriver, and put the tip on each of the pumps or base of each pulley, and the handle end to your ear, and you can hear the bad bearing "scream" with the engine running.
Be blessed.
Mar 28, 2013 | 2000 Nissan Quest
97 wrangler wont drive forward in 2wd. just makes a loud grinding noise but will drive in reverse
sounds like rear end is coming apart
google wrangler forums and post there
Feb 03, 2013 | 1997 Jeep Wrangler
Very loud squeaking noise - like a noisy loose fan belt on a car.
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Mar 24, 2017 | Frigidaire FDE336RE Dryer
Really loud whirring/squealing noise
Yes, It is still safe but very annoying...
The source is probably the guide rollers for the drum or the belt tensioner pulley. To know for sure you will need to pull the dryer apart and turn it by hand slowly and see where the noise is coming from...
Heatman101
Mar 03, 2010 | Whirlpool Dryers
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Carrier Air V unit with loud noise
If it sounds like a scraping noise it could be the motor bracket ah broken and the squirrel cage (fan assembly) is hitting the fan housing, if it is more of a squeal than it very well could be a bearing. Very hard to guess without seeing or hearing it.
Nov 02, 2009 | Carrier Heating & Cooling
My vac is really loud now is that the belt??
Sounds like the brush roller is worn and making noise, take the complete vac to the repair shop for service. I've seen this cause damage to the front nozzle housing as well.
Oct 13, 2009 | Hoover Elite Rewind Bagless Upright Vacuum...
Loud screeching noise coming from the unit.
A screeching or squealing noise usually comes from the fan motor. There may be an oil port and you can buy a small telescoping oil bottle at a super hardware store or an a/c supply house. Before putting in he oil, remember to TURN OFF THE POWER TO THE UNIT and only use a light squeeze on the bottle - over oiling will cause a mess inside the motor. It may be a sealed motor and no oil ports. In either case, budget for a new motor as if it's to the squealing stage, the bearings are already damaged and it's a just matter of time before before the motor bearings fail. If possible, get oil on the bearings ASAP - and use the proper lightweight oil for made for this application.
May 05, 2009 | Amcor PLM16000 Portable Air Conditioner
Began making loud squealing noise
sorry thats probablly the transmission going out it could be the main unit itself, if thats the case time for a whole new trans, but sometimes its the mechanism that turns the trans off and on, and those parts can be replaced independantly from the transmission iself but you would have to tear the whole thing apart to get it out but more importantly back in. a local vac shop with more than five years experience should be able to fix it.
May 17, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
