Question about Nordic Track NordicTrack Treadmill, A2550
Treadmill turns on but wont start when u push buttons
Image 19.0Q Treadmill. Console lights up but how to unlock the buttons?
If you wish to get some details about treadmill repair; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 27, 2016 | Exercise & Fitness
Bremshey treadmill maintenance,treadmill wont run until i have safety button pressed in
Your treadmill should not run without the safety button pushed in, or safety key in. this is to shut the unit down if you were to fall.
Sep 21, 2013 | Exercise & Fitness
Golds Gym Treadmill motor will not start after sitting idle for about a year
see the video and fix it. However after you did this and the problem remain, you must test a) control board or b) replace the old board deck belt.
Mar 24, 2013 | Golds Gym 450 Treadmill Drive Motor
Belt wont start on a brand new Sole F80. Motor
It sound like the motor control board is the culprit. Unplug unit then remove shroud then find the 2 leads that connects the motor to the motor control board disconnect them then plug in unit and see if the display blackout after programing the display then hitting start.
Mar 12, 2010 | RTO Sole F80 Treadmill
My console does not allow me to change the incline, speed, etc. The control panel does not acknowledge the buttons pushed. I've turned it off and on.
my treadmill is doing the same thing. the only buttons that work are the start; incline up. 4 incline; 8 incline; and 11 incline.
Sep 26, 2009 | Reebok 8700 ES Treadmill - Silver Service...
Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
May 10, 2009 | Exercise & Fitness
Treadmill Won't Start
you need a new lower board from the mfg. you can replace this item you self if the make the part still call them.
Apr 18, 2009 | New Balance 1400 Treadmill
Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Apr 14, 2009 | Proform CrossTrainer Treadmill
Nordic Track NordicTrack Treadmill, A2550 Logo
16 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
