Question about Jensen MP7610 CD Player
Radio turns on but wont play any sound
I was puting in a amp when some kinda eletrical shock happend every thing made a louad bumbing static nose and the radia got real hot and smelled like some thing was burning i stoped working with it i got every thing put back to gether the right way but it wont play any thing it turns on like it just fine but nothing comes outa the speckers i tested the speckers to see if they may have blown but they work just fine arnt blown...i cant seem to figure out why it wont play nothing
    President:
  • 205 Answers
You may have blown the out put chip in the radio
Posted on May 21, 2009
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
Hi, my amp just died, i turned it on than the led lighted um and died, now i wont turn on ...
UNPLUG THE AMP
First you need to check any visible fuses either in the plug or on the back of the amp.
If you have an electrical testing screwdriver or meter you can test the fuse. If this sounds like gobbledegook (daft talk) then stop and take it to the dealer where you bought it.
If you can remove the fuse or fuses then replace them if it is obvious they have blown - dark and kinda burnt looking.
If replacing the fuses doesn't fix it - STOP.
Valve amps are serious bits of electrical hardware - they are not for home repairs - take it to a GOOD dealer / repair shop that deals with valve amp - nowhere else should play with it. When they have it sorted you can have the valves re-biased/changed to adjust the amp for the sound you want - yes the valves can change it.
Hope this helps - don't mess with it - even when turned OFF valve amps can give you a shock!!
Keep on Rockin'
Feb 18, 2011 | Orange Amps Orange Amplifiers AD Series...
I have the pioneer AVH 3200BT and when I plug in the special adapter to play my iPhone music I get crackling or a static noise
what kinda adapter ans static usually means bad connect or bad wire when radio is on and u hook it up and it just crackels for a sec itll usualy allways does that with me just hook it up b4 u turn on
Oct 17, 2010 | Pioneer Car Audio & Video
Car radio wont turn on !!
try disconect for 1 minute and check the 10 amp fuse in back
Mar 14, 2010 | JVC KD-G430 CD Player
No sound on am or fm only static but sound with cd player
check the antenna connection. you may have to open up the radio to fix the problem, and may require soldering. I recomend butane powered soldering gun since it produce no stray current like an eletric soldering gun.
Nov 23, 2009 | Bose Wave Radio
Hi,I turned on my Marshall mg series 100 dfx and there is no sound,just static comes on.Its starts with a kinda bad feedback sound than turns to loud static.
I suspect the power supply for the effects processor has failed. The effects unit will "go crazy" when power supply is too low voltage.
If the amp has loud noise, then the power amp portion is PROBABLY OK.
I had a similar problem in a Behringer amp caused by a bad electrolytic filter cap.
Aug 11, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Cobra MicroTalk PR-3550WX - Static after transmission
Dear sir, try to operate ur radio in different channel ,( ur operating area seems to be have so dense radio smog ..if u are located near some border where ur adjacent frequency is in use this cud be the problem .
first try in low power channel ( 8-14) ..if it solves ur problem ok ur u try to contact ur seller , & get it replaced if its under warrenty period.
Regards
raj
May 26, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Plays radio not cds
You may have Power antenna and amp remote turn on wires switched. Your system may be looking for turn on signal from radio and only gets it when am or fm is on because power antenna wire is hooked up instead of amp turn on signal.
Jan 18, 2008 | Kenwood Sirius KDC-MP522 CD Player
Jensen MP7610 CD Player Logo
143 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
