F2 40 error code
My copier "Sharp AR5620SL"is showing f2 error, when I press the start key it shows 40 as sub code. please help me to rectify this problem
3 Suggested Answers
sir fixalot
  • 146 Answers
SOURCE: error on sharp copier
That has to do with the laser unit and/or the white shading plate.
First remove the platen glass and clean the white strip on the bottom side. BE CAREFUL FOR THE GRAY OR BLACK LINE ON THE STRIPE IF YOU WIPE IT WITH A SOLVENT AND REMOVE THE LINE YOU ARE DONE.
If the unit is making a whining noise it is probably the laser unit polygon motor.
If the scanner mirror system is hanging or not returning to home position check to see that the scanner lock on the underside of the scanner where the paper comes out is unlocked.
Posted on Jun 06, 2008
SOURCE: sharp ar5516 f2 error
We have bought this machine on Date-28/07/2011 and it is still in warrenty. now already 11,000 copies put it And the now machine shows F2 indication after starting and the company not repairing it. And the after sell service of company is not good.We tell the company to change the the machine or repair and they neither repairing it nor changing the part.
I request you to solve my problem please.
Posted on Dec 14, 2011
Error code E7
It would be helpful to know the error sub code. With the error showing press and hold your start/copy key, this will provide the sub code.
Thanks
Follow me on Twitter @CDOS_Service
Jan 09, 2014 | Sharp AR-M205 Copier
Sharp ar m550n error codesError code F2How can i fix it ?Help me plz , Thank
press and hold start key to show you sub code and send for me but i think you toner cartrige shode chenge
Dec 18, 2013 | Office Equipment & Supplies
Having error code H4 showing on my AR155 sharp copier. How can I resolve it please?
After error occurs please press the Start button then it shows the sub error code. I need that code to give a solution.
Mar 21, 2013 | Sharp AR-150 Toner
Sharp ar5516 f2 error
Nov 14, 2011 | Office Equipment & Supplies
Canon image RUNNER 6000 Copier error E 000001-0000
there is a problem in fixing unit. You can try to reser error code in service mode, but if the error persist after clear, you need to rectify the problem and replace fault component is fixing assy. The problem can be in thermistor, sub thermistor or dc controller pcb, or ... call service!
To reset error code:
while ready to copy/showing the error code:
1) Press the user mode key ( * ) on the control panel.
2) Press the 2 and 8 keys at the same time.
3) Press the user mode key ( * ).
Choose: COPIER>FUNCTION>CLEAR>ERR
Turn off and back on the copier.
Aug 22, 2011 | Canon imageRUNNER 6000 Copier
How do i rectify error code h4-01?
first you have to enter simulation mode:
#/P key (program) ON ? Asterisk (*) key ON ? CLEAR key ON ?
Asterisk (*) key ON ? Ready for input of a main code of simulation
2) Entering a main code with the 10-key ? START key ON
3) Entering a sub code with the 10-key ? START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key to start the simulation operation.
main code is 14, sub code is 0 in your case.
H4-01 means Sub heater lamp abnormally low temperature detection.
You may also have a dirty/defective thermistor in the fuser unit.
Oct 29, 2010 | Sharp AR-M237 Digital Copier
H400 error
it is problem heater unite
reset code is
C photo C photo press 14 by copy quantity key press printkey then show 01 or other code press up & down key 00 press print key
Jul 27, 2009 | Sharp AR-168S Copier
F2 ERROR CODE
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
Oct 22, 2008 | Sharp AR-C160 Color Copier
Error E7
Hi, before i can help, you need to press the print button and it will show a 'sub code', which will determine the exact fault.
Cheers
Andy
Feb 22, 2008 | Office Equipment & Supplies
Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Jan 05, 2008 | Sharp AR 163 Copier
12 people viewed this question
jasbo
jasbo
