Question about APS20B Prestige Keyless Remote Alarm
Where is the valet switch? 2002 Jeep - APS20B Prestige Keyless Remote Alarm
Where exactly is the valet/override switch in a 2002 ford explorer. My explorer is on total lockdown
There is not a valet/override switch on the factory system. it is programmed with the keys.
Aug 15, 2015 | 2002 Ford Explorer
Where is the valet switch located on a 1998/9 jeep grand cherokee? any pictures of this switch?
what makes you think there is one, reading the wrong
operators guide?
98 is gen 2 jeep, 99 is gen 3, so which is it? one or the other.
WJ or WK
i this switch is not a stock jeep part, nobody can guess unless
the custom alarm is stated and its model number, period.
there is no valet switch, sorry, not by jeep
why not post symtoms, and then work real issues, not phantoms.
some cars the valet is used in the , normal ignition key slot.
the 04 has a valet button under dash.
lots of rumor.
https://www.google.com/webhp?gws_rd=ssl#q=jeep+grand+cherokee++++valet+key+switch+location
what is the problem, car will only run for 3 seconds. that it
this is SKIM failure. (or other 6 reasons for ASD relay drop out)
post symptoms and win.
Mar 30, 2015 | Jeep Grand Cherokee Cars & Trucks
I am trying to program a new fob for my Alert starter and cannot find the Valet switch. I have an 04 Jeep Liberty.
i'm not sure that there is a valet switch , follow this u-tube link to see procedure for programming new fob , i hope it's the same as your system
How To Program New Jeep Liberty Remote
Jun 05, 2014 | Cars & Trucks
I have a prestige remote Audio box starter remote alarm on a 2002 Toyota Camry.I unplugged the sensor and the car still doesn't start.can you help me i am out of the state need to get home.
Locate the valet switch( black push button), turn ignition on, press and release valet switch. the valet switch is plugged onto the main control unit. You can find the main control unit by tracing the harness that you unplugged from the shock sensor. The valet switch is plugged into a two pin plug and has a blue end. Trace the wire to the valet switch.
Jul 10, 2011 | Prestige Remote Start
95 Jeep cherokee alarm went off and will not let car start. I use to be able to by pass it by grounding it and now that is not working. Do you think turning the ignition to on position for 10 minutes as...
is this a stock alarm or after market alarm? most after market alarms have a valet switch. to put it in valet mode flip the switch and turn the ignition switch in run mode.
Apr 23, 2010 | Jeep Grand Cherokee Cars & Trucks
Where is the valet switch for honda accord 2002 lx?
Does the vehicle have an aftermarket alarm system? Is the valet switch for this what you are looking for? If so, it depends entirely on who installed it as where they have put it, although it's usually under the dash on the driver’s side. Some alarms have different sequences that you have to go through to put the alarm into valet mode; it's not usually just a switch that you flick. Best to pop into an alarm or stereo installer and see if they can spot it for you, or if the car is immobilized, find out what sort of alarm it is and call an installer for the info on the valet procedure.
Thank You for contacting Fixya.com
Aug 03, 2009 | 2008 Honda Accord
Valet Switch/Button
Contact a dealer for the location of switch
May 02, 2017 | 2002 Mitsubishi Galant
APS20B Prestige Keyless Remote Alarm Logo
19 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
