Baumatic washing machine error code e33 - Washing Machines
SOURCE: Baumatic washing machine instructions
the twelve programs are explained on the detergeant drawer.if not i will post them for you.
to use the dryer turn the middle knob clockwise to the amount of time you desire upto 140 minutes then select the temperature on the far left knob and then depress the half load button your dryer should now work.
Posted on Jan 02, 2008
SOURCE: Baumatic BTWM6 washing machine flashing F02 error
hi, you need to empty the filter, ours does the same all too often. The filter is located bottom right of the machine at floor level, which is rather daft for an integrated applicance; we have to remove a whole length of plinth to empty ours. Be warned, a lot of gunge and water will come out so have towels at the ready, especially if you have a laminated floor. Turn the white slot with a a 10p piece......and empty. Not the most pleasant of jobs, but effective. Good luck!
Posted on Mar 18, 2009
  • 1416 Answers
SOURCE: Baumatic WQP12-9213 - Error Code 004?
hello
The "004" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
mean while 004 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the 004 error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
Posted on Jun 03, 2010
Testimonial: "Thank you for your help."
SOURCE: BAUMATIC BFW1000W
Hello. I too am having the same problem with this model. Did you find a soultion at all. Also I can post you a copy of the user manual if you are still interested?
Posted on Aug 14, 2010
  • 18 Answers
SOURCE: I have no instructions on how to installa baumatic bwr 1206 wasing machine
Hope this helps :)
http://talkappliance.co.uk/downloads/?sa=view;down=103
Posted on Apr 23, 2012
What does e33 mean on a baumatic washing machine
not saying this is whats wrong with it i just found this on the internet............hi, you need to empty the filter, ours does the same all too often. The filter is located bottom right of the machine at floor level, which is rather daft for an integrated applicance; we have to remove a whole length of plinth to empty ours. Be warned, a lot of gunge and water will come out so have towels at the ready, especially if you have a laminated floor. Turn the white slot with a a 10p piece......and empty. Not the most pleasant of jobs, but effective. Good luck!
Dec 11, 2016 | Baumatic Washing Machines
How to clear error code E 11
Which model do you have?
What happened that led up to the error?
If you are sure there is no problem or problem has been fixed, try the reset button.
Reset Buttons for Washing Machines
Nov 27, 2015 | Baumatic Washing Machines
Machine stops during the spin, especially with heavier loads.
Maybe you overload your washing machine. Minimize your washing machine usage to avoid stopping during the spin.
Aug 23, 2015 | Baumatic Washing Machines
The erore E33 little swan front loading w/ machine
I suggest that you search online for "error code e33 + little swan" you'll find most websites will offer some information.
Jul 11, 2015 | Washing Machines
My Electrolux washing machine is showing error codes MB Alarm E33, and UI Alarm E00. It has stopped working altogether. Door wont open and clothes are stuck in ther. I have run a diagnostic test and it...
I appreciate your post, Anonymous!
From what you have described your Electrolux washer is displaying an error code of MB, E33, and UI Alarm E00. I have been unable to locate those error codes. May I have your model number, please? With that information I will be able to assist you further. -Matt
Mar 19, 2015 | Electrolux Washing Machines
Baumatic fault code E11 Baumatic BFLW75 60cm 7.5kg
Look under the machine, for a bag with the
diagnostic manual, they do not want you to find
You will need that to run a self check & get it working
again
Try unplugging the machine, but most likely it has
the codes stored on the circuit board
Aug 15, 2014 | Washing Machines
Error code E33 on electrolux Washing Machine
Hello - I am happy to assist you. However, are you certain that the error code is E33? From my research this manufacturer does not have an E33 error code for any of their units. Could it possibly be E32 or E35? If so, it is related to a pressure sensor issue. Either it has detected a pressure senor calibration error or an overfill water pressure sensor problem. Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart washer. If it proved to be ineffective, contact a professional to properly diagnosis the unit and move forward accurately.
Feb 13, 2013 | Washing Machines
I have a stirling washing machine xqb90-701clps and the machine has come up with an E4 error code.. cannot find my manual. what does that code mean?
my machines not washing properly i think.. The wash is complete but theres still powder on the clothes.. What do i do to solve it?????
Jul 25, 2010 | Washing Machines
E33 error
E33 means that you've run out of toner. replace the toner cartridge
May 23, 2008 | Copystar CS-1500 Copier
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
