Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Sony blinks 4 times - Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Sony tv model KV-HA21M80 is having problem front stand by L.E.D is blinking 4 times and stopping
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Electro help
Jan 14, 2015 | Sony Televison & Video
The light blinks red continuously on my kdf55e2000 sony tv
Hello, does it blink in a pattern (example:blink 4 times pause and repeat 4 time blink)? Please let me know. tks
Nov 01, 2013 | Sony Grand WEGA KDF55E2000 55" Projection...
I have a sony 50". in the power button, a red
i have a sony 57". in the power button, a red blinking light blinks 11 times.
KDP57W5655
Nov 28, 2010 | Sony KP-51WS500 51" Rear Projection...
No picture or sound. Red light blinking four times on sony bravia tv. Suspect power supply problem?
Red light blinking 4 times on Sony bravia TV.This is the problem of INVERTER BOARD.The inverter board has to be replaced.Every Sony bravia tv has a particular model number and the Inverter board part number depends on model number of the tv. As you have not mentioned the model number so the exact part number of the inverter board is hard to tell.But you can get the required inverter board part for your tv from www.partstore.com ----------- Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation.
Aug 18, 2010 | Sony Televison & Video
Sony Grand WEGA KF-50WE610 LED blinks 4 times
4 times blink shows Temp Error and requires temperature sensor replacement in Sony KF-50WE610 TV
May 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Feb 13, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony 60" wega kdsr50xbr1 blinks red 4 times
Please check Fans are running in your DLP Sony TV as 4 times blinks shows that any one of four fans is stopped or not running.
Feb 10, 2009 | Sony KDS-R50XBR1 50" HDTV
50" sony wega blinks red at intervals of 4
This is 4 time blink details for TV Sony KF-50WE610
4 times error shows that one or all 3 fans (cooling) are stop and need to be checked.
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KF-50WE610 no picture?
4 blinks = No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505.
Nov 28, 2006 | Sony XL-2100U Projector Lamp for...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
289 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
