Question about SanDisk Electronics - Others
Firebird6up9 formatter - SanDisk Electronics - Others
No display
There are a couple of causes. First you need to try to do an engine test to see if the print engine is working. If it does not, remove the formatter and try the engine test again. If the engine test works, then there is a problem with the formatter. Might be either fax modem, memory or harddisk or the formatter itself. Remove components from the formatter one at a time to see if you can do an engine test with the formatter installed.
Sep 18, 2015 | HP LaserJet 9500mfp Printer
HP 9500mfp no display
No display in most cases will be a bad formatter. Try to run an engine test with the formatter installed and then removed. You need to ensure that there is paper in tray 2 when doing the test or it will fail and you will think there is a problem that does not exist. If it will perform an engine test with formatter removed but not when installed you have a bad formatter for sure. Or possibly bad memory on the formatter.
Hp laserjet 9500 control panel failure after removing rhe formatter.
Control panel will not light with the formatter removed, it is controlled by the formatter. The only thing you can do with the formatter removed is an engine test.
Apr 28, 2015 | HP Office Equipment & Supplies
P3015 hp lasser printer 49.4C01 error proper solution
Sounds like a bad formatter. I would try a firmware upgrade first and if unsuccessful, would replace the formatter. These formatters are infamous for failure.
Feb 22, 2015 | HP RB1-3015 LaserJet 4L Laser Scanner...
T1120ps formatter board replacement
3_7_2012_9_04_00_pm.jpgHi above formatter snap shot located at back side of left door. Unscrew both sides & pull up to remove,fix another formatter in same manner.. But how you confirmed that formatter faulty? Do you checked light pattern?..pl take experts advise before replacing the things.
Mar 06, 2012 | HP DESIGNJET T1120PS 44 Printer
How to replace a formatter board on hp p3005 printer and is there a way you could print the printer configuration first without replacing the formatter board first?
i don't know if can be any shortcuts to print the configuration if the formatter doesn't work properly. the configuration is stored on formatter memory. if the formatter is in good condition you may follow the menu. to change the formatter is pretty easy. you can search a manual on internet.
Jul 07, 2011 | HP LaserJet P3005n Printer
Hp p4014n, erro 55,00,00 controlador, cc
55.XX.YY DC CONTROLLER ERROR
A temporary printing error occurred.
1. Turn the product off and then on.
2. Remove any third-party memory or USB
device, and then turn the product off and
then on.
3. Remove and then reinstall the formatter. (the formatter is the logic board)
4. If the error persists, remove the
formatter and perform an engine test***. If the engine test page fails to print,replace the DC controller. If the engine test page prints, replace the formatter.
***engine test
To verify that the product engine (all product components except the formatter, formatter DIMMs,
EIO products, and the stacker or stapler/stacker) is functioning, print an engine-test page. Use a small, non-metallic, pointed object to depress the test-page switch, which is accessible through a slot in the right-side cover.
The test page should have a series of horizontal lines.
A damaged formatter might interfere with the engine test. If the engine-test page does not print,
try removing the formatter and performing the engine test again. If the engine test is then successful, the problem is almost certainly with the formatter, the control panel, or the cable that connects them.
Jun 01, 2011 | HP LaserJet P4014n Printer
My machine is powered up but the screne does not have anything displayed. All the lights (ready, data, attention) are lit up.
The last time I ran into this problem it was a faulty formatter. Your first step is to remove the formatter and reseat any memory dimms or cards on the formatter. Always power off printer and unplug before removing/installing the formatter. If pirnter does not start after reseating memory, unplug printer again and remove formatter and start printer without formatter installed. Once you have powered up the printer, look for a small hole on the back of the printer, Upper left side if you are infront of printer, right side if you are facing the back. Use small object like paper clip to push the button which will generate an engine test. If it prints, then the formatter is most likely bad, but firmware on formatter may also be corrupt.
Jun 01, 2011 | HP LaserJet 4700 Printer
My M2727nf is not not initilizing and is out of warranty I sent it to an othorized HP service center and they told me that I need to change the formater. Where can I buy this formater and find the guide to...
1. Remove the left cover.
2. Disconnect five connectors (callout 1; GND wire lug, J36, J2, J32, J34) and five FFCs (callout 2;
J4, J27, J28, J31, J26).
Remove the formatter (1 of 5)1
132 Chapter 5 Removal and replacement ENWW
3. Remove six screws (callout 3), and then separate the formatter from the product.
Remove the formatter (2 of 5)
CAUTION: Make sure that you install the protective sheet behind the formatter when you reinstall
it. Failure to install the protective sheet might cause a short circuit and damage the formatter.
4. For products that use an Asian character control panel only
: use a pair of needle nose pliers
to release the Asian-character control-panel-display PCA spacer from the formatter.
5. For products that use an Asian character control panel only: remove the Asian-character
control-panel-display PCA from the formatter. Install the PCA on the replacement formatter
(connector H3).
Here's where you can get your formatter... Click Here!!
Hope this heps and if so Please mark this a FixYa!!
Jul 17, 2010 | HP Laserjet M2727nf Multifunction Printer
MEMORY CARD CORRUPTED
you should formatt the memory card...
go to menu
select the extra settings
open the memory card icon
and press options and select
formatt memory card....
and select yes..
and wait until it complete formatt.
and press ok..
Jan 06, 2008 | Nokia 6600
Electronics - Others Logo
905 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
