Question about Akai LCT2660 26 in. HD-Ready LCD Television
No power problem.
Looking for replacement P/S for Akai LCT2662 or a repair solution for no power on problem.  Does any one know how to component-level this 200watt unit. Thanks
  • 2 more comments
  • arccorjc Dec 17, 2007
    My problem is the same as I see several of on the 2660, trouble turning it on and then it progressed to where it won't come on at all, a little glow in the red light and no activity, there are several solutions none of which really address the problem, there is no back light in the 2660 as one solution suggest, and the others do not really provide answers or should I say solutions...
  • mdplbg Dec 31, 2007
    Will not power on. This happened little by little at first I could toggle backand forth to get on but finally it went completely out.
  • syslink Feb 03, 2008
    I saw in a previous post that listed the capacitors on the power board to replace. I tried their recommendation of replacing all the caps and Good God Almighty, it WORKS! Just when I was about to kick it to the curb! And to think that Akai wanted $400+ for a replacement when I spoke to them last year!! Thank you very much!!
    David
  • Anonymous Apr 14, 2008
    AKIA 50 inch TV won't power on. While watching it the screen faded out with digital green blocks then went blank but the sound kept going. When picture didn't return we tried to cut it off. Remote would not cut it off and on/off button on tv would not cut it off. We cut off by the switch on the back. Now the red light will go to green and it sounds like a fan running but no picture and no sound. HELP!! This tv is only 2 years old and cost 1500 at the time, I really can't afford to replace it.
  • 871 Answers
It may be a circuit board problem which the resistors and capacitors are involved. there will always be a shorted fuse there also.
have a veteran or certified electrician take a look and let him look for any burnt fuses,and any stuff there.
Posted on Apr 01, 2008
If anyone wants to sell the screen for the akai let me know 727-514-2313
Posted on Feb 14, 2008
    Champion:
  • 367 Answers
I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Posted on Feb 02, 2008
I need to know the amp size of fuse to replace on AKAI LCT2662. thanks
If you have the original fuse, it's the number stamped on one of the end caps after the three letters denoting the fuse type. Most manufacturers also print the fuse rating on the power supply circuit board ("Caution: replace fuse only with...")
I have one of these sets in the shop now, but I haven't opened it yet. Post a reply if you can't find the fuse type and rating, and I'll let you know what my project uses.
I assume you already know fuses in TV sets don't blow by themselves, but indicate another part is shorted. Check the diodes, transistors and power ICs in the power supply before plugging the set in. If you see any bad capacitors, fix those also.
Sep 28, 2010 | Akai LCT2662 Television
Is there a hdmi port on this tv akai lct2662
try the following website >tvtoptenreviews.com< then select feature comparison, this will give you a list of all products, you'll have to scroll down to your model.
Sep 15, 2009 | Akai LCT2662 Television
The power supply on my Akai LCT2662 (Flat screen TV) has gone bad
I went to Radio Shack and purchased a replacement power cord 18-gauge, 10 amp, 1250 watts for 9.00 bucks and it works fine.
Aug 19, 2009 | Akai LCT2662 Television
LCT2662 turns on, no picture
Mine is the 5volt regutator. It works fine untill I put a load on it then it craps out. Need to know what the 5v regulator part # is.
Dec 22, 2008 | Akai LCT2662 Television
AKAI LCT2662 Schematic
I was looking for the same thing- I found this, which I am 99% sure is the same TV under a different name - even the remote is identical.
MODELO: BSV-2652
May 24, 2008 | Akai LCT2662 Television
Akai
have akai lct2662 screen is bad power supply and board ar good tom.schulty@gmail.com
May 09, 2008 | Akai LCT2662 Television
Power supply
Call 800-726-4405 - But the part may not be available - request an exchange through the manufacturer. By law the manufacturer must provide parts for 5 years.
Mar 25, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
AKAI LCT2662
Power supply most likely... It's a common problem with this particular model and we've seen quite a number of them for exactly what you're describing.
You need to replace 19 caps in the power supply 4) 3300uf/35v, 8) 2200uf/25v, 6) 1000uf/10v, 1) 1000uf/16v and you can go a little higher in the voltage of each cap for greater reliability.
It's best to have an ESR meter also and test the remaining caps as well.
Bill
Mar 18, 2008 | Akai LCT2662 Television
OFF AFTER 10-15 MINUTES
This is usually caused by damaged capacitors (Akai uses very cheap components) on the power supply board. There are nine large electrolytic caps that have to be replaced. Hope this helps you out.
Feb 05, 2008 | Akai LCT2662 Television
Akai LCT2660 26 in. HD-Ready LCD Television Logo
103 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
