Question about RCA D32F750T TV
D32F750T - picture jitters and is unstable
Had to replace shorted flyback. After installation the picture now sometimes (not all) has many noise lines through it in horizontal bands, and menu words are noisy and jitter. Sometimes its ok for a while then other times its awefully bad. Happens on all inputs.
tvtek
  • 1284 Answers
SOURCE: RCA D32F750T TV
Did you adjust the two controls on the new flyback? The top one is almost always the focus control and the bottom is the G2/screen control (brightness) If you adjust the G2 do it until the picture looks normal, too high and you will get retrace lines through the picture.
Posted on Jan 26, 2007
  • 11 Answers
SOURCE: horizontal bands
you may have a problem with the vertical output IC.
Posted on Jan 08, 2008
jerryg50
  • 1667 Answers
SOURCE: RCA pix tearing horizontal lines
Get an ESR meter and check all the electrolytic capacitors in the set! I am sure you will find many decoupler and coupling capacitors that are on the edge or too high in ESR.
Jerry G.
Posted on May 25, 2008
  • 223 Answers
SOURCE: RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Posted on Oct 03, 2008
tomswrldtech
  • 90 Answers
SOURCE: horizontal width jitter after turn on, or picture
hi there, seems you're encountering horizontal width suddenly adjusted by itself. i recommend you unscrew the back casing, clean the crt board a bit and look for the capacitor on the secondary output of the transformer voltage chopper. it has this diode series with the output and filtered with electrolytic capacitor. if you notice bulgy appearance replace it with same type and farrad rate. most of the times it is unnoticeable by just physical checking. Some are leaky and can be determined using capacitance tester. The supply of the Vertical IC is not stable cause by this capacitor. replacing most of the capacitor wouldn't cost you much. hope this helps, please rate and vote
Posted on Mar 26, 2011
I need flyback part number for an rca tv model D32F750T tankyou
http://www.partstore.com/Model/Thomson/RCA/D32F750T.aspx
part number is 265515 and above is site selling it.
SD TECH
Jun 16, 2011 | RCA D32F750T TV
My tv. proscan mod. ps50700 won`t turn on
The PS50700 uses the 195 series chassis. The most common cause of the set not starting up is a shorted flyback (high voltage) transformer. Sometimes a shorted flyback will also cause the horizontal output transistor to short too. These parts need to be tested and/or replaced by a tech familiar with the RCA 195 chassis.
Aug 17, 2007 | Proscan PS65000 65" Rear Projection...
Picture has the jitters and horizinatl lines
Check power supply board for bad capacitors they will be swollen,vented or puffed up on top . Let me know if you need anymore help.
Mar 23, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Vertical jitters on picture - JVC AV48P776
What you are experiancing is loss of High voltage. The line is called a retrace line. It is usally caused by failure of the flyback circuit or aging of the TV tube. This is the single most common failure with CRT based display systems. The high voltage can be tweaked up, to accomidate for the age of the tube. Its a short term solution. Because of the high voltage nature of this circuit, suggest a professional repair.
Jun 29, 2009 | JVC AV48P777 Television
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
Symphonics vhs/tv combo
thats usually means the flyback or the horizontal output transistor is shorted. i would replace the flyback thats most likely the cause. If you need me to post a link of where you can get a replacement flyback with instructions how to reoplace it. please let me know
May 23, 2008 | Symphonic SC3813 13 in. TV/VCR Combo
SCHEMATICS
Dear,FixYa I thank you for your concurn,however I've fixed that problem upto two mounth ago,the problem was the flyback,if you was to ask me how did I get to that conclusion,when I was caldin to to that TV,by pushing the switch the green light click's in and then out again, so I went right to the HOT only to find it shorts out,so I replace it,and at the push of the switch it went again so,I know the flyback is the problem so I replac it and that was it,however am new to my computer,however I mention about schematics because I know that no one can do troubleshooting properly with out it,how ever I have on my bench a QSC RMX 2450,pushing out voltage on right channel,any information on that that I can use hopeniy might help me thank You.
Apr 30, 2008 | RCA D32F750T TV
Jitter and tearing on bright pictures
1. VERT JITTER/HORZ UNSTABLE-CHECK 'GE' CONNECTOR PIN 5 FOR 1VPP Y SIGNAL INTO PIP PCB THEN CHECK 'GE' CONNECTOR PIN 11 FOR 1VPP Y SIGNAL FROM PIP PCB. IF SIGNAL AT PIN 5 IS GOOD AND PIN 11 IS CLIPPED OR REDUCED. CHECK ALL ELECTROLYTICS (I.E.C7001, C7014, C7026, C7036) AND ALL CONNECTING TRACES TO THESE CAPS FOR CONTINUITY 2. HORIZONTAL TEARING, VERTICAL JITTER. SIGNAL RELATED CONDITION. APPLY FOLLOWING CIRCUIT CHANGES ON PCB-SIGNAL: A. REPLACE R2K8 WITH A 1K RESISTOR (BASE OF Q2B2). B. REPLACE R2K3 WITH A 47 OHM RESISTOR (IC201 PIN 50). C. ADD A 100PF CAPACITOR FROM BASE OF Q2B2 TO JUNCTION OF R2L0 AND R2K6 (GROUND).
Jan 21, 2008 | Mitsubishi VS-60611 60" Rear Projection...
50"sony wega
Dont plug it on your tv the FLYBACK of your tv was defective. Need to replace your flyback or else more parts inside was damage. Bring your tv to a Electronic tech.
Jan 01, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
RCA D32F750T TV
Jan 25, 2007 | RCA D32F750T TV
RCA D32F750T TV Logo
85 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
