Question about Hammering
Jackhammer quit in middle of use
Using a jackhammer to break up garage pad. The power got less and less and then it died. Let it rest but still did not start. Did I kill it? What can I try to get it to work?
  • petronellaf7 May 21, 2009
    Thank you! I will check these two things and see if that's it.
    President:
  • 205 Answers
If it is an electric jack hammer the brushes in the motor maybe worn out. most ace hardware stores have a good selection of motor brushes. also check to see if the brush retension screw came loose this would also cause the same problem.
Posted on May 21, 2009
Was using my Bosch brute 70lbs jackhammer and it quit working. It only makes a humming sound when I press trigger.
Beware Time for service something does blocking the armature if that happens a bearing or other broken part.
Apr 17, 2017 | Bosch Hammering
Smelled burning wire and then stopped running
It can also be a suppression capacitor by the switch , or the electric field itself one or both coil fiels are gone.
Mar 29, 2014 | Hitachi DH40MR Jackhammer
Bosch jackhammer
To long without service , or problem with a broken part ? or an problem with a electric field (slide contact somewhere ) or one of the carbon brushes is autostop activated ?
Or simple a cable break , a switch with a problem ,
Mar 27, 2014 | Hammering
What is a jackhammer actually?
A jackhammer is basically a combination of a hammer and a chisel.
Jan 31, 2013 | Hammering
Chicago 46935 armature i need 1
Chicago jackhammer 96035 is the same model W/ different accessories. Use this model when ordering parts from Harbor Freight, total cost W/ shipping and tax will set you back about $40.00
Sep 25, 2011 | Electric Demolition Jackhammer
Hammer runs but bit does not move much
how much oil do i put in my bosch jackhammer?
Jan 30, 2011 | Electric Demolition Jackhammer
Kango 950k
it sounds like it needs service,service is taking lower unit apart cleaning and regrease with special kango grease, if unit was serviced recently or not used much, grease could be real old and dry,sometimes you have to warm up unit before they start hitting correctly,,also if used a lot could be dirt build up,inside bit holder.remove bit holder clean out dirt regrease with heavy bearing grease,just grease the lower part,not very much grease is needed
Jul 28, 2009 | Electric Demolition Jackhammer
No LED power lights go on
the light with the power light(middle) is a blue/purple faint light try checking it out at night.The squiggy(as heat waves) will only light when the amps shuts down due to thermal protection(wait for it to cool). The bolt/yellow (short circuit) will light when there is an electrical overload in any of the wires(check +ve leads).
May 26, 2009 | MTX JackHammer JH202 Car Audio Amplifier
"jackhammer" sound coming from my washer
# Balance the load
# Level the machine
# Inspect the water pump for a blockage
# Inspect the coupling
# Inspect the transmission
# Adjust the drive belt tension
# Check the motor bearings
# Check the drum brakes
Jan 09, 2009 | Washing Machines
Hammering Logo
874 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
