Question about JVC HR-A592U S-VHS VCR
I have a JVC Pro-cision 19u head VCR but cannot set the time and date or set up recording
2 Suggested Answers
  • 11 Answers
SOURCE: recording
most vcr's dvd's and recorders have to have the remote..if you have cable or satellite, you can program that remote to run your other equipment under aux. or you can buy a inexpensive universal remote that can be programed to run your equipment.
Posted on Dec 09, 2009
Will universal remote control work for JVC Pro-Cision 19u Model No. HR - VP670U
The IR commands are pretty universal across most JVC VHS decks. So if that exact model isn't listed, they'll be another that's close enough in the range of functions that you have all the basics covered.
Aug 30, 2014 | Televison & Video
I need a downloadable manual for a JVC Procision 19U Head Plug N Play VCR
I have a pro cision 19 u heade vcr and I can not set thet date and time on ththe vcr I turn off the VCR and I do not get the menu up on the tv screen so that I can also set Sp And Ep
Oct 16, 2011 | Televison & Video
How do i record a show onto a tape?
lets say you are hooked up correctly (cable to VCR in (from cable/sat box) & cable to TV from VCR out) and the VCR is set to Ch 3,, (PLEASE NOTE THE TV MUST BE ON CH 3)
program a recording
the VCR clock / date must be set and not flashing 12:00
then you go to menu, program a recording by imputing the start time / end time of the show and the date it will be recorded and Ch 3...(you might have to set your cable box for the same date/time as the VCR or manually turn to that ch you wish to record that morning or before you go to bed) put a new tape in the machine....
manual recording
a show,game or special comes on and you sitting and want to watch and record and even edit (no commercials) put tape in... press record button get the remote so you can pause (on commercials) and press pause again to resume recording
HAVE FUN
Dec 26, 2010 | Sony SLV-678HF VHS VCR
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
My jvc has developed a tracking problem when viewing tapes recorded on other recorders. I cant seem to correct the problem. It shows old tapes without a problem
VCR tracking has to be set up right, but even then many machines have problems with tracking other vcr's tapes. Generally a good quality commercial tape should track well. If it doesn't then either there's a fault with the tracking on your machine or the tracking is not set up right. Most tracking problems are caused by dirt, or wear on the heads or surfaces. Give your VCR a good clean up, every surface the tape comes into contact with, using Servisol Video 40. If that doesn't solve it you might have to look into the cost of replacing heads, maybe the control/audio head first. Or you should look at having the tracking set up by a proffessional (at a JVC service center). However if the tracking was off, after resetting any tapes the machine has done, may now have problems tracking, whilst other machines tapes and commercial will track normal.
Jun 28, 2010 | JVC HR-S6970 S-VHS VCR
Recording
Dec 08, 2009 | JVC HR-VP673 VHS VCR
VCR not timer recording, VCR will not turn on with timer
If no menu, unplug, and let it set a few minutes. Replug and the on-screen menu should appear. Reset the set-up (date, etc). I had the same experience as one of the other posters with JVC customer service telling me the menu button on the remote was malfunctioning, and I should purchase a new remote from them.
After you input your programming, be sure to hit the Timer button on your remote. If you want to change tapes or playback, you will need to hit the Timer button again (take it off Timer) for access to your VCR. Be sure to reset it to Timer afterwards, or you will not be able to record.
Feb 17, 2009 | JVC HR-A592U S-VHS VCR
VCR won't record at a set time
Check that the clock on the machine is set to the correct time and date. Check am/pm.
This problem is usually caused by incorrect time & date.
Mar 30, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
Sound
What does "having no sound" mean?
- no sound on playing a known good tape?
- no sound after recording?
- no sound when recording if you plug in headphones or into a monitor?
Nov 05, 2006 | Philips VR540 VHS VCR
JVC HR-A592U S-VHS VCR Logo
41 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
