Question about HP Officejet Pro L7680 All-In-One Printer
Inserted non-hp ink cartridges. need reset.
Inserted refilled non-hp cartridges.
  • 1 more comment
  • devininstl May 21, 2009
    I think I might have the same problem, and I need help too. I'm using a re-manufactured ink jet cartridge from Concord Supplies. It's worked well for about three months, and now I'm getting an error message that says "The following ink cartridge(s) are not intended for use in this printer, please see printer documentation." Like I said, it worked well for three months with this ink, I've used the re-manufactured ink cartridges before and one day it just stopped. It won't print or fax, but I can still scan. Not sure what to do to fix it.
  • jjethro May 22, 2009
    HP L7680 Put in a generic replacement ink cartridge and it says "The following ink cartridge(s) appear to be missing or damaged.
    K
    Refer to printer documentation.
    I've used generic replacements before.
    Is there some wire that we can short out to override the little chip on the ink cartridges?
  • jjethro May 11, 2010
    I have removed the CR2032 memory backup battery from the circuit board. This did not fix the problem. There are four blue wires that run across all of the printer cartridges that are connected to a small circuit board that then appears to feed with several wires across the printer to the right side where the main circuit board is. I'm guessing that it is some form of digital polling to the chip on the ink cartridge. The guys that make the chips either don't know it all or something because the one I bought was advertised as auto reset, but it doesn't.
    Does anyone have a mechanical or electronic override so that this can be prevented?
  • HP Master
  • 419 Answers
You'll need to be clearer about your problem.
What error messages are you getting?
What cartridges are you using?
Are they refilled or 3rd party cartridges?
... the more information, the more likely I can provide a solution.
Posted on May 21, 2009
6500a plus non hp cartridge over ride does not work
For print cartridge errors you may try following the article: Print Cartridge Errors. However, since they are refilled ink cartridges HP cannot guarantee that they will work correctly.
Can I Refill The Ink In My HP Ink Cartridge?
Don't forgot to say thanks by giving "Kudos" to those that help solve your problems.
Read More Help... HP Printer Support
Jul 24, 2014 | HEWLETT-PACKARD 6500A Plus InkJet Printer
Ink refill costco hp printer C4780
When you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena, the 2nd video provides suggested cartridge prep/handling instructions when you return the cartridge for refilling:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings:http://www.youtube.com/watch?v=C5ISTGyScWU
Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=FnXoDIblpdU
If the new (or refilled/reman/compatible) HP 74, 75, 74XL, or 75XL ink cartridge refuses to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. If you run into a problem where the ink cartridge is performing marginally and blocks printing (via the Red X), you can bypass the error message (usually only 1 time per clearing action):
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=UDxRkAGOJaI
HP Officejet J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=3X3_D90SSq4
These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem", etc.) typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. You can also run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test).....go to www.inkjet411.com for more information on your specific printer model.
Feb 16, 2013 | HP Photosmart C4580 All-in-One InkJet...
How to reset hp 901 ink
When you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered by Costco and Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels CANNOT be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty - it uses fusible links so the electronics are literally blown - thus non-reversible).....so you just need to live with the low ink messages and ignore ink low, non-genuine, counterfeit, fraud messages and similar while you are using these types of refilled or aftermarket ink supplies.
Refer to Inkjet411.com sitelet for all printer models which use refilled ink cartridges (most major brands and models) - see videos below on HP 901 and 901XL low ink warning messages, along with all the other more severe error messages:
http://inkjet411.retailinkjet.com/
Jul 24, 2012 | HP OfficeJet J4580 All-In-One Laser...
HOW TO RESET 920 INK CARTRIDGE ON HP OFFICEJET 6500 AFTER HAVING IT REFILL
FYI, you cannot reset the ink it self. If your using an HP refilled ink cartridge the warranty of your printer will be void. you need to contact HP right away to purchase new ink cartridges.
If the cartridge has been refilled or remanufactured, 'Low on Ink' or 'Ink Alert' messages may be inaccurate or display incorrectly.
Jan 31, 2011 | HP Officejet 6500 Wireless All-in-One...
Check color printer cartridge--I refilled the cartridge the orinter doesn't accept it"
Hi
When a non professionals refill there cartridges
air bubbles are left in cartridges durring refilling process
so when cartridge need ink to heat and spray it on paper has air and that time is when is getting overheat it and need to be replaced
check here how you can refill it your cartridges with no errors on your printer
In case I had help you pls vote me
Oct 28, 2010 | HP Photosmart 2575 All-In-One InkJet...
Just installed refilled black ink cartridge on hp
By using refilled cartridges you will always have this problem. Each cartridge has a chip that lets the printer know when it is full or empty. By pressing the ok button you may be able to clear this message. However, most of the time you can still be able to print and ignore the message.
May 28, 2010 | HP Deskjet D4260 Printer
Is it possible to use non HP ink in ths printer? Tried using "remanufactured ink", and concluded that this printer may be programed to block the use of NON HP INK.
It is always recommended to use genuine HP cartridges.
As if we will use the non HP or refilled cartridges, it will reduce the life of the printer.
And we will get an error "cartridge problem".
Plaese use the below cartridges, which are compatible with this printer.
HP 02 Black 660 pages
HP 02 Black Twin Pack 1320 pages
HP 02 Color Combo See single 02 inks
HP 02 Cyan 400 pages
HP 02 Light Cyan 240 photos
HP 02 Light Magenta 240 photos
HP 02 Magenta 370 pages
HP 02 Photo Value Pack 150 photos
HP 02 Yellow 500 pages
HP 02XL Cyan 600 pages
HP 02XL Magenta 555 pages
HP 02XL Yellow 750 pages
Apr 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
How do i make printer accept refilled cartridge t
Maybe you did not refill and insert it very well.
follow this steps in refilling your ink
1. remove the ink cartridge from the printer
2. make a hole at the top end of the cartridge, the hole can be made under the label on the cartridge by using a sharp/hot pin.
3. if you are using a syringe and needle in refilling, make sure you did not insert it into the hole too much so that the cartridge does not get damaged in the process.
4. make sure the ink is not over-filled to avoid spillage which can cause a hell of damage on you printer as it does to my previous one.
5. Gently use the label or a masking tape to cover the hole and insert it into your printer.
Note: The printer gives a message that the cartridge is empty or non compatible, ignore the message and continue with your printing.
It is also advisable that you refill your cartridge not more than 2 times.
If this solution does not help you, contact me on holamydes@gmail.com for more assistance.
Aug 15, 2009 | HP DeskJet F4280 All In One Printer InkJet
F4280 printer and hp 60 cartridge
keep the cartidge in Hot Water for 30 minutes. maybe it works.
May 30, 2009 | HP DeskJet F4280 All In One Printer InkJet
How to reset the ink level for a HP 60 ink cartridge? I have just refilled a HP 60 black ink cartridge but can not find anything on how to reset the ink level. I would do the "3 ink cartridge" trick but I...
You cannot reset the ink level indicator for the HP 60 ink cartridge. It shouldn't matter anyway because the level is only estimated for "management purposes only" (see user manual) meaning to let you know when it's near time to order a new cartidge. I have tried cycling through 3 different cartridges to reset the ink level for the one I refilled but it didn't work. Refill and just ignore the ink level indicator. Also, it's a good idea to clean the print heads with the solvent in the refill kit before refilling to remove old ink and imrpove print quality.
Apr 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
HP Officejet Pro L7680 All-In-One Printer Logo
608 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
