Question about Ford 555 backhoe
1986 655A BACKHOE-STARTER PROBLEMS - Ford 555 backhoe
I have installed a new starter on my 580C backhoe When I turn the starter switch it will not engage wheel and just akes a whirring sound Have taken it out and reinstalled it but get the same results
I can talk to you in automotive terms, I know nothing about a backhoe.
I can usually lay the starter motor on the ground, hook up jumper cables properly from starter to battery, at the least, it should kick out the starter drive gear and spin. If it doesn't kick out the drive gear, starter is faulty. I don't know if starter solenoid sits on top of starter motor? I replace as an assembly. Did you check flywheel teeth? I've never worked on a backhoe.
Feb 25, 2017 | Cars & Trucks
Why wont my takeuchi backhoe not start when it is hot?
Jims excavator #30 Part two of my starter installation on my ...
? 13:50
www.youtube.com/watch?v=EoEMoBb1bPU
Jan 12, 2012 - Uploaded by JimsEquipmentShed
This is the second time I've put this starter in, so this time around, instead of removing the rops and ... Thanks! i have a problemwith the heating in de cab. ... B-) The Takeuchi is a great machine though, I'd buy another one.
Aug 05, 2015 | Cars & Trucks
I have a 310g john deere backhoe with F9C4 & F9a3 that will not start motor just turns over how do I fix it
jump the starter to see if it is good if good check then silinoid starter jump that with jumper wires connected to battery if dosnt starter silinoide
Sep 14, 2014 | Garden
How to change injector pump on CAT 428f backhoe?
Try to loosen the nuts on the fuel lines going to the injectors and crank the engine till all the air bubbles are removed from the system. Don't crank the engine for longer than 30 sec at a time letting the starter cool down before cranking again.
Jul 17, 2014 | Caterpillar Backhoe Tractor
Is there a seal behind starter?
You have a torque conventer seal out.
May 11, 2014 | Ford 555 backhoe
I have a kubota bx25 that won't start. it has power to the starter on battery side
you need to have power to the small wire on the starter for it to crank over
Sep 03, 2012 | Woods Kubota Bx 24 Bx 23 Bt610 Bh75 And...
I have a cat 416 backhoe that keeps burning up starters. Can't figure out why. Any Thoughts?
eather a bad ground wire or the flywheel is bent witch will put to mucth of a load on starter
Jan 05, 2012 | Caterpillar Backhoe Tractor
No starter engagment on cat 420d bachoe no power
From what I have discovered with my own Cat 426 it is likely the forward reverse selector. It has electronics and contacts that will NOT allow the starter to receive any power if the contacts are open as there are safety interlocks that will not allow the machine to start.
May 18, 2010 | Caterpillar Backhoe Tractor
Case 580C Backhoe starting problems
either you have a short in the wiring, a loose connection somewhere or a bad starter, check for broken wires first and clean connections. then try the starter see if it turns with a direct connection to another battery
Jul 14, 2009 | Champion International Garden
Garden Logo
26 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
