Question about Danby Dehumidifiers
Danby ddr7009 runs but doesnt pick up water - Danby Dehumidifiers
4 Suggested Answers
  • 11800 Answers
SOURCE: My danby ddr7009 has been
The unit behaves like the Timer function was activated and set for a one minute - a ridiculously small time limit that is not normally selectable, the minimum being one hour.
Look at the command board and check if the witness light for the timer is on - right to the left of the temperature digits, to the left, above the timer button. If it's not on try to reset the bad setting by activating the Timer: press on the button and set a time of at least 6 hours.
If the unit still refuses to work correctly or even accept the new setting then the control board has been damaged during the power outage and it will have to be replaced.
The board is very sensitive and even the slightest spark that occurred on its power line has created a surge large enough to damage the processor . To prevent this from happening again you will need to use a surge protector.
Posted on Sep 05, 2011
  • 884 Answers
SOURCE: Dehumidifier Does Not Shut Off
Switch it off when you go out. Find replacement float switch
Posted on May 15, 2012
Testimonial: "HAPPY with the Danby now!"
  • 884 Answers
SOURCE: DANBY DDR7009 REE dehumidifier "Auto" shut off Malfunction
See previous answer. If new, contact supplier to replace float switch. Are you sure it's not just a fan staying on with the tank out?
May 15, 2012 | Dehumidifiers
May 15, 2012 | Danby Dehumidifiers
Hello i have a dehumidifier Danby DDR586R water runs out of the bottom of unit
is the condensate resovoir in place correctly or full? take it out and put it back in.
May 10, 2012 | Danby Dehumidifiers
I have a Danby Silhouette and the fan works but the dehumidifier doesnt.
Bryan, it may imply be a case of the humidity extraction level being set to high. Lower the level to 35% and see what happens. As far as the fan running is concerned. Most dehumidifiers are designed for the fan to run, even if the compressor doesn't turn ON. It's designed to keep the air circulating and if the humidity rises above the setting you have it on, the humidity sensor will pick up this change and turn the compressor ON.
Also, remove the air intake filter to see if it's clogged and needs cleaning. Maintain at least a minimum of 12" of free air space all around the dehumidifier. Poor air circulation will prevent the unit from working properly. As will, to low an ambient air tempeature. Most unit struggle to work at temperature between 40 & 60 degrees F.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 04, 2011 | Danby DDR451 Dehumidifier
Hi I have Danby Dehumidifier about 2 year prolem is Compressor and fan running but no water and heater
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Nov 27, 2010 | Danby DDR586R Dehumidifier
Danby preimere dehumidifier will not draw water from the air? No working?
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Jul 27, 2010 | Danby DDR601 Dehumidifier
Danby dehumidifier SAR403H-3;
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 06, 2010 | Danby DDR2504 Dehumidifier
Danby DDR401. Can't get it to remove moisture from the air.
Hi Fred, let me see if I can assist you. If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
May 27, 2009 | Danby DDR401 Dehumidifier
Kenmore dehumidifier
heatman101
Mar 11, 2009 | Danby DDR606 Dehumidifier - 60 Pints...
Dehumidifiers Logo
26 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
