Question about Siemens HF87950GB Convection Microwave Oven
Start button not switching microwave on - Siemens HF87950GB Convection Microwave Oven
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
Apr 10, 2017 | Kenmore Microwave Ovens
Why doesnt start button work on microwave oven?
In modern Microwaves switches are printed on two sheets of pvc foils and are activated by pressing them by thumb or fingers. With constant use, the surface of the switches becomes defective due deposits of nonconductive material, dust or carbon etc.
The solution is exact replacement of the keyboard, irrespective of other switches working or not. If the replacement keyboard is not
available, the defective switch can be salvaged by tracing back the two printed lines to the originating points on the hard board of the microwave. Get two insulated wires soldered to these points and solder the other ends of the wires to a mechanical push button and fix the same outside the body of the microwave at a convenient place. If the defect was in the printed circuit key board, pressing the new switch should start the microwave.
Aug 25, 2014 | Microwave Ovens
Start button does not work
the switch contacts are not making so switch is u/s
Jul 05, 2010 | Panasonic NN-T993SF Microwave Oven
Hotpoint RVM1435 when I push start button will not start unit?
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 30, 2010 | Hotpoint RVM1435 Microwave Oven
The microwave oven start button does not work. If
You probably have a bad door switch or door switch mount and should see these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If it's not the switch or mount, you may need to adjust the door alignment.
If you still need help, to allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and requote your symptoms, as you posted previously.
Dec 06, 2009 | Sharp R-1870 Convection/Microwave Oven
Switching off the sound of my Samsung Microwave
1 Press the Sound button. The display shows "ON".
("START" will flash)
2 Press the Sound button to turn the volume off. The display shows:
"OFF".("START" will flash)
3 Press Start. The display returns to the time of day.
Lastly, you can find a copy of the manual here:
http://downloadcenter.samsung.com/content/UM/200507/20050727140356453_DE68-01945A[GB].pdf
Sep 01, 2009 | Samsung MW1030WA Microwave Oven
Will not start when pushing start button
Check the door switch is properly working. If it is ok the defect may be with the key pad.
May 23, 2009 | Frigidaire Mid-Size Microwave
Kenmore over the range microwave 721.67600 will not cook
One of two thing happened here...
1. most likely...One of the interlock switches has malfunctioned. Micro. will NOT opperate unless ALL switches are working properly for safety
2. possible...the start button on the touch pad has failed in the circuit.
Feb 23, 2009 | Kenmore 62702 Microwave Oven
My microwave start button doesn't push in to start my microwave
The keypad is a thin plastic membrane type that is glued to the plastic control panel frame.
It's most likely that the keypad is worn out or possibly you have a flaky door switch.
We have full details, critical safety, disassembly, and troubleshooting info (as well as door switch testing info) at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually order Samsung parts (either the keypad / membrane switch or control panel with keypad) from http://www.samsungparts.com but that model number is not showing up, so you may have to call or e-mail them through their site.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 27, 2007 | Microwave Ovens
The start button of the keyboard does not work
I would first suspect the door switches. The door must be shut and the switches must be working before the contoller will let the oven start cooking. See my other answers for a text file on door switch testing and replacement. Once they have been checked, if you still have toruble, please reply back.
Dec 10, 2006 | Welbilt MR99T Microwave Oven
Siemens HF87950GB Convection Microwave Oven Logo
91 people viewed this question
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Steve
Gerry Harvey
Gerry Harvey
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
