Distilled white vinegar. The acid in it will also neutralize the ammonia in the cat byproducts and won't make things sticky. Apple cider vinegar still contains sugar and other impurities like pectin that can leave a residue. Distilled white vinegar really isn't vinegar at all. It is actually grain ethanol that has been converted by a special bacteria into acetic acid, which makes vinegar sour, then it is diluted to 5% acidity like A.C. vinegar but without all of the residue that can attract dirt and dust to your furniture. Good luck.
hi Jeff.
not saying this will work,but its all i could find on the internet. Sprinkle baking soda on the surface being cleaned (as long as it is safe to do so). Scrub with a sponge or plastic brush to work in the baking soda. Rinse with clean water and the vinegar smell should disappear.24 Dec 2009
https://www.hunker.com/12001359/how-to-get-rid-of-a-vinegar-smell
What will neutralize the smell of vinegar?If the smell of vinegar lingers and you just hate the smell, open a box of baking soda and leave in the room that smells. The baking soda will neutralize the smell of thevinegar.What are some ways to get rid of the vinegar smell without removing ...https://www.quora.com/What-are-some-ways-to-get-rid-of-the-vinegar-smell-without-re...Search for: What will neutralize the smell of vinegar?
How do you get the smell of vinegar out of a car?Sprinkle baking soda over the carpet before vacuuming it to remove odors.Blot the area affected by the vinegar if it is still damp. ...Sprinkle baking soda over the affected area of carpet and let it sit for about an hour.Vacuum the carpet thoroughly.Reapply more baking soda and vacuum again if necessary.How to Remove a Vinegar Smell From Carpet ' Hunkerhttps://www.hunker.com/13421004/how-to-remove-a-vinegar-smell-from-carpetSearch for: How do you get the smell of vinegar out of a car?
or go to this link might help you out more. How to get vinegar smell out Google Search
Prevent lint from clinging to clothes by adding 1/2 cup white distilled vinegar to the wash cycle. To remove soap residue that makes black clothes look dull use white distilled vinegar in your final rinse.Get stained white socks and dingy dishcloths white again.
Add 1 cup white distilled vinegar to a large pot of water, bring it to a
rolling boil and drop in the articles. Let soak overnight. Some stains on clothing and linens can be soaked out using equal parts milk and white distilled vinegar.Before washing a mustard stain, dab with white distilled vinegar.ttack spaghetti, barbecue, or ketchup stains with a white distilled vinegar and water solution.Remove perspiration odor and stains on clothing,
as well as those left by deodorants, by spraying full-strength white
distilled vinegar on underarm and collar areas before tossing them into
the washing machine.Forgot that you left wet laundry in the machine and it now smells moldy?
Pour a few cups of white distilled vinegar in the machine and wash the
clothes in hot water. Then run a normal cycle with detergent.Remove smoky odors from clothes
by filling the bathtub with very hot water and 1 cup white distilled
vinegar. Hang the garments above the steaming water and shut the door so
the steam can penetrate the fibers.Keep the steam iron clean and in good working order by
getting rid of mineral deposits in steam vents and spray nozzles. Fill
the water chamber with a solution of equal parts white distilled vinegar
and distilled water. Set it in an upright position and let it steam for
about 5 minutes. When the iron is cool, rinse the tank with water,
refill and shake water through the vents onto an old cloth. Test before
using.Remove scorch marks from an iron by
rubbing it with a warmed-up solution of equal parts white distilled
vinegar and salt. If that doesn't work, use a cloth dampened with
full-strength white distilled vinegar.Remove musky smells from cotton clothes by sprinkling them lightly with white distilled vinegar and then pressing them.Get water and salt stains off shoes and boots by wiping them down with a solution of equal parts white distilled vinegar and water.Give patent leather shoes and bags a better shine by wiping them down with white distilled vinegar.Get cleaner laundry!
Add about 1/4 cup white distilled vinegar to the last rinse. The acid
in white distilled vinegar is too mild to harm fabrics, yet strong
enough to dissolve the alkalies in soaps and detergents. Besides
removing soap, white distilled vinegar prevents yellowing, acts as a
fabric softener and static cling reducer, and attacks mold and mildew.Eliminate manufacturing chemicals from new clothes by adding 1/2 cup white distilled vinegar to the water.Remove soap **** and clean the hoses of your washing machine
with white distilled vinegar. Periodically run the machine with only a
cup of white distilled vinegar in it-nothing else added to the wash
cycle.Bring out bright colors by adding 1/2 cup white distilled vinegar to the rinse cycle.Fluff up wool or acrylic sweaters (hand- or machine-washed) and rid them of soap smell with 1/2 cup white distilled vinegar in the last rinse water. Get rid of the tiny holes left along the hemline
when you take out the hem of any garment by moistening a cloth with
white distilled vinegar, placing it under the fabric and ironing.
that smell is usually caused by a build up of soap and residue from normal laundry,, a simple way to fix this is to run a empty full load add 2 cups of vinegar to the load, it will help in the breakup of buildup in the machine,, after that ,, run a load on Hot to drain out any left over vinegar
i had what sounds like a similar problem. i complained of our laundry smelling sour then finally like sour sewage and a flooded laundry room. i was told that when its not draining properly, it can create a siphon-effect and actually pull the dirty water back out of the drain lines-yuk! i hope this isnt true.
there was a baby sock stuck in the pump preventing it from draining properly. hope your problem can be remedied as easily.
as for the smelly clothes, i always add 1/2 cup white vinegar to each load. it does wonders for odors.
That is comon with LG.
Clean out the filter in the front.
Than take an OLD towel.
Wash with chlorox first a hot load. After that do the same but than with vinegar and that should take care of the SOUR problem
I have an LG too.
My friend told me of someone who researched this problem, and it is because we are using liquid detergent. Switch to a granular high efficiency detergent. Before you start using it, you must run through a mixture of about one cup Clorox and two cups vinegar through the washer, using the Sanitary setting. I am actually on-line now trying to research the exact proportions of Clorox and vinegar when I ran across your problem.
