Question about Oxo Good Grips POP Rectangle Storage Container
Unjam the pop up grip on an OXO container. Website only shows how to clean the lid, not up jam the handle
We have a fellowes shredder. It got full and jammed. After cleaning and emptying it will not turn on. Is there a reset button? Thanks. Betn
We've found that when the container is overfilled with shredded paper, it will begin pulling shredded paper back into the cutters and jamming the machine. Sometimes reversing the machine will spit the paper back up, but if it is thoroughly jammed, only way to unjam it is to UNPLUG it first, then manually remove the paper from the cutters. Then, be sure to dump the container BEFORE it is filled with paper.
Jan 12, 2017 | Fellowes Office Equipment & Supplies
My hp printer 5525 shows carriage jam how can i fix this?
If you lift the lid to get access to the cartridges, there should be a diagram showing you how to unjam the carriage. I have a 564, & it has that feature.
Aug 05, 2016 | HP Photosmart 5520 Multifunction Inkjet...
Why do the numbers on the oxo digital food scale appear only in half?
Sounds as though the LCD display is faulty and only half is lighting up. I would have thought the cost of replacement is greater than the scales are worth. May be a bad connection that needs resoldering, but usually they are not serviceable.
Aug 03, 2015 | Oxo Good Grips 11-pound Digital Kitchen...
How to change the hour on the OXO triple grip timer.
The instruction booklet for OXO's Triple Timer Model ## 1071501 can be downloaded here:
http://www.oxo.com/download/556_gg_1071501_booklet.pdf
Mar 10, 2015 | Oxo Good Grips Triple Timer
OXO food scale shows erh code
I am having the same problem with the 5lb scale. Turned it on for the first time about 5 days ago and was ok. This morning when I went to use it it gave the ErH code. Would appreciate if any person has an answer. I am waiting for OXO to respond my e-mail.
Apr 14, 2013 | Oxo Good Grips 11-pound Digital Kitchen...
How to unjam the lid to an OXO Good Grip Pop Container
replacement parts can be found easily on amazon. here: Amazon com OXO Good Grip Pop Container parts I hope this was helpful. Cheers
Mar 20, 2013 | Oxo Good Grips POP Rectangle Storage...
Wear do you put the water
Inside the main tank is another container for clean water.
To fill it, lay machine all the way down. Lift handle and remove container. Take to sink, turn handle, and remove lid. Fill with hot, clean water. Replace and lock the lid. Place container back into tank and put handle down.
Sep 29, 2010 | Bissell 1699 ProHeat Clear View Upright...
Oxo Good Grips POP Rectangle Storage Container Logo
288 people viewed this question
Top Oxo Home Experts
Donni Steen
ray gallant
Are you an Oxo Home Expert? Answer questions, earn points and help others
