Question about Ariens Garden
How do you rotate the chute on an ariens ss522e snowblower
Can't rotate the chute
5 Suggested Answers
harlan301
  • 205 Answers
SOURCE: how do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Posted on Oct 12, 2009
SOURCE: ariens 520 snowblower the rotating blades are not
check on the shaft they are mounted on and there might be a bolt that goes all the way through it. If so they are shear bolts that can break if you get something stuck in the blades. Just replace the bolt if broken or missing.
Posted on Dec 26, 2009
  • 6 Answers
SOURCE: Snowblower seems weak for a 5HP
Check to see if there any surface rust inside the auger assembly. This will cause this problem. Also, you try a silicone spray on a painted surface.
Posted on Jan 06, 2010
wireguy212
  • 1627 Answers
SOURCE: ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
Posted on Feb 17, 2010
Craftsman snowblower chute won t turn. the cables just spin inside the gear that rotates the chute left and right.
take chute apart where it pivots
theres a square hole that is now rounded
get some hard plastic 2 part glue from auto parts store
warm it all up build up sides flat again. or buy all new parts
my way is $7 or less and yes ive done this
Feb 03, 2014 | Craftsman 28 In 277cc* Dual-Stage...
Ariens snowblower problems
The snow blower does not throw snow. Snow jams up in the chute
Jan 04, 2014 | Motorcycles
Ariens snowblower impeller not throwing snow
Feb 13, 2010 | Ariens 34 In. Zoom Series Riding Mower
I have an Ariens 624 series snow blower and every time I use the snowblower the snow spits out of the chute. How do I get the snow to BLOW out of the chute far? I've tried tightening the cord for the...
Looks to me like your second stage is not working. If the auger is turning fine, look and see if the secondary thrower is turning. Probably a shear bold on one or the other is broken. Easy fix, but do not put your hands in there when the machine is running!
Jan 09, 2010 | Garden
Ariens 520 snowblower the rotating blades are not powered by the engine and are just spinning?
Dec 26, 2009 | Ariens Garden
I have Ariens Model # 1336DLE snow blower aprox 5 yrs
A volt meter or test light will be needed. Also a 12 volt battery supply ( you can use an automobile battery or your automobile)
*Please Note: before testing, make sure all wires and connections are tight and not corroded, loose, or burnt. Many electrical problems are just loose, broken, or burnt wire connections.
Test the chute rotator motor: you will need to disconnect the motor from the wiring harness.
1) connect a wire to the 12 volt supply and one of the motor leads
connect the other wire to the remaining lead
*note: positive or negative does not matter, because the chute motor will rotate either direction, and by reversing leads, the motor direction will reverse.
2) If the motor is good, now check for voltage from the snowblower engine.
Locate the supply wire to the rotator switch, with the engine running, check the voltage reading on that supply wire.
3) If the supply is good, then the switch is bad
Nov 15, 2009 | Ariens Garden
it will run at the speed you set at it may bog down a little when you hit the snow and the belt problem on the side there is a cover take it off there is an ajustment try to tighten the belt if that doesn't work you may have to replace it, thank you.
Sep 09, 2009 | Garden
Ariens ST 724 impeller does not move under stress?
i have a old ariens ST724 snowblower engine will only run with full choke.
Jan 29, 2009 | Farmall Cub Tractor Radiator
Ariens 926LE snowblower won't engage forward or backwards. Running fine
First thing I would check is to make sure the traction drive belt didn't fall off or break. To do this remove the plastic shroud between the engine and the snow chute. The traction belt is the one closest to the engine.If it isn't broke Make sure it is on the upper and lower pulleys.
Dec 21, 2008 | Garden
Ariens 1336 snowblower chute fell offf..reset it on top of ring,but it is unstable and any rotation causes it to fall over and off the track and ring. how is chute secured to ring and the mechanism/gear...
Go to www.ariens.com then click on parts, click where it says click here, then enter 1336 where it says model name/ number then you will be able to find the breakdown for your machine you will need model and serial handy to find out which one is your machine cause they list several different models for that number then click on your model and on the right side click on illustrated parts list then it will give you a complete list of the breakdowns for your machine.
Dec 13, 2008 | Garden
Garden Logo
79 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
