Question about Garden
Pullrope won't pull out
The pullrope on my Poulan Weedeater Featherlite will only come out about 3" when I tried to start it. I've tried to find a manual for it but could not locate the model #.
  • scusemi May 21, 2009
    No. The rope won't pull so it doesn't turn over.
  • sirskruffz May 11, 2010
    does the motor turn over?
  • 155 Answers
Hi try this web site its called pats small engines but you will need the model it lists about 20 featherlite models
Posted on Jul 26, 2009
How can I start featherlite weedeater with poulan carburetor sst 25?
Your Poulan should have a green button on the side of it. Push and hold it. While most models have a green button, your may not. In that case, obtain the model number off the weedeater, go to Poulan.com/customer service and download the manual for your machine
Sep 01, 2014 | Poulan Recertified - Weed Eater...
Does poulan featherlite weedeater have a compression releif valve
It barely has a motor. No it has no need for compression relief.
Aug 11, 2012 | Poulan Featherlite Plus Gas Trimmer
Poulan 2050 14 inch chainsaw . Problem is ,it wont start. Has been good saw. Seldom used.while idling it quit running.so I went to refuel and noticed, it was not out of fuel.I pulled fuel filter to clean...
Same same for me as well ..need to rebuild a small engine
sorta fun on a small engine you can do it at kitchen table with your wife playinf solitare OR get a tV table and rebuild it on the porch
poor start scalled port good catch on your part to notice scorch
Jun 16, 2010 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
I need a manual for a 25cc 2 cycle featherlite weedeater
try going on the internet to
poulan.com/manual, can d/l a manual from there
May 28, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
Need to obtain a new belt and pull rope for my Tiller
you can get a pull rope at wal-mart.measure the belt and any parts store or place that sells lawnmower belts should have one.if the rope broke close to the end knot just pull the end knot with some needle nose pliers.once you have all the old rope out lay the old rope pieces on the ground and cut the new rope to match it as far as length.turn the pulley that the pull rope goes in six turns counerclockwise.then turn the slot the knot was in to the hole the pullrope goes thru and fish it thru then pull it up and out with apaiar of needlnose have someone hold the pulley until you tie a small knot in the end of the pullrope the hold the pullrope and let it pull it in.you might have to cut some off at the handle if its still too long.to do this pull some rope out and tie a quick knot so the rope can't slip back if you let it go.
May 27, 2010 | Mtd Products Yard Machines 158CC Tiller
Pull Cord Will Only Pull Out 3-4 Inches Then Sticks
Take it apart as you did before. Look for whatever it is binding. Did you rewind the rope so there is a good amount of tension? If you didn't, then do that . Good luck, Lee
Sep 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I am trying to repair the fuel intake on a featherlite weed eater
replaced fuel lines on sear weedeater and primer button still acts like it is suching against a vacume. push it in and it won`t release. this unit in same as my featherlite carb and tank. What do I look for line are not restricted, but car not drawing fuel?????
Jul 08, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Pullrope broke on weedeater 550 how do i get it apart to fix it
ther eshoul dbe some bolt holding the pullcord/recoil assenbly to the flywheel/motor. you need to locate and find these bolts first. let me know when you have this apart. you have to unwind the rope and pull it completley out, then buy a new pullcord rope(other rope will just fray and break agai) slip it thru the holes tie a knot wind up the spring and carefu;lly place it back on were it came. let me know if you run into any trouble.
Apr 23, 2009 | Poulan Pe550 Gas Edger
Garden Logo
452 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
