Philips tv repair manual
WHERE IS THE PICTURE FUSE LOCATED AT, PLEASE? THANKING IN ADVANCE.
2 Suggested Answers
  • 42 Answers
SOURCE: Have a black vertical bar
I own this TV in the 43" size.
My set is also 10 years old.
It could cost you anywhere from $300-$500.
The life is about 15-20 years
Posted on Jun 02, 2011
Philips Flat Panel model 32PF7320/98 error code.
4 blinks is according to the manual... POR bit / +8 V protection
In other words the 8 volt DC power circuit is going into shut down, so you would need to troubleshoot that part of the power supply
Dec 01, 2017 | Philips 32PFL3403D/27 32 in. LCD TV
Philips HD tv has no picture
common fault this , normally the fuse has failed on y-main board due to shorted thick film unit
unfortunately its not a cheep repair job.
Aug 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
NO PICTURE OR SOUND
Hello mtf420ak,
I do not believe this is a problem with a fuse since by your experiment both fuses are good. Now put the fuse back in and if there is still no picture and no sound we can assume that the problem might be some other component on the power supply board, and or the High voltage section because this sounds like a shutdown circuit problem. If it is a shut down circuit problem the section that might be malfunctioning would be the High voltage section of the TV. I would suggest that you let a qualified TV technician troubleshoot and repair this television. I say this because this is not a simple problem, this is an issue that requires a knowledge of electronics and TV repair.
I hope this helps
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 03, 2008 | Philips Magnavox 51MP392H Rear Projection...
Zenith System 3 Model # SR2571DT
if you know how to solder , then resolder your tv ,maybe your tv had a lose connection.
Oct 12, 2008 | Zenith C27A24T 27" TV
Picture problem on Toshiba 42inch WH36 series
These capacitors are on Hyper Board. You have to replace in order to fix the problem. See the link: http://www.diyforums.net/projection-tv-lines-1327.html
Apr 17, 2017 | Televison & Video
Cigarette Fuse, 2001 Taurus, No Owners Manual
the fuse is red in color is a 15 amp and is in the panel on the left of the steering wheel behind the panel.
Sep 02, 2008 | 2001 Ford Taurus
Repair of Phillips 21GX 1563 94R TV
replase the capaciter 100mfd 40v located near vartical out put ic.
Mar 09, 2008 | Televison & Video
Sony kp48s35 (rear projection tv)
You need to have the crt px tubes checked for heater to cathode shorts, a picture tube restorer is needed to refurbish one or all three tubes to restore balance to tubes. Sony has a px muting built into the circuitry to save the tubes from being destroyed. If one tube is conducting more than one of the other two the imbalance is detected and causes picture (px) muting... blinking on & off the picture. Most repair shops have this crt restorer on hand.
Jun 07, 2007 | Sony KP-48S35 48" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
