Question about Motorola Mobility H371 Bluetooth Headset
Low volume motorola h371 paired to iPhone
Volume on headset on highest setting, very faint
map9966
  • 2351 Answers
SOURCE: maual for Motorola H350 bluetooth headset
This may help. Click the link:
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/AU-EN/H350_User_Manual_19oct2007.pdf
Ignore the chinese as you go. Its like mixed together but you'll find what you need. Good day!
Please vote.......
Posted on Jan 17, 2008
SOURCE: Motorola Bluetooth HS850 Pairing Mode
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
Posted on Jun 04, 2009
  • 23 Answers
SOURCE: my h710 will not go into pairing mode. I have
Make sure your phone is in discover as well. Also make sure your holding down all 3 buttons at the same time for at least 10 sec. then it should go into discovery.it will blink then go solid.
Posted on Aug 19, 2009
  • 23 Answers
SOURCE: H710 won't go into pairing mode
sounds like its already connected to the iphone but it won't establish them. Delete the pairing from the phone then repeat the process.
SOURCE: Trying to pair my Motorola Headset H681 with my
the pass key is 0000
Posted on Jan 01, 2010
The sound is low when playing music and volume is up on iPhone and headset
Start playing and then increase volume. When you are on a different screen, volume increase or decrease doesn't apply to iTunes.
Nov 01, 2014 | Motorola Mobility S305 Bluetooth Headset
Volume will not increase only have extremely low volume
Ensure sound on headset and on phone are increased. Some phones allow you to control volume on headset so setting to low on one while high on the other may offer poor experience.
Mark
Motorola Support
May 23, 2014 | Motorola Mobility H790 Bluetooth Headset
Where is the volume
Little buttons on side of headset. Typically the factory setting is for right ear. So volume button on top would be up volume and bottom would be lower volume.
Mark
Motorola Support
May 20, 2014 | Motorola Mobility H371 Bluetooth Headset
Need password to connect to my phone. Motorola bluetooth H371
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps..
Thanks for using fixya...
Oct 27, 2010 | Motorola Mobility H371 Bluetooth Headset
I'm trying to pair a Motorola H371 to a Blackberry Bold 9650. I can't find the password for the pairing. Do you know what it is?
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
Sep 29, 2010 | Motorola Mobility H371 Bluetooth Headset
Need pairing code for h371
The pairing code or passkey is 0000 (four zeros)
Thanks for using FixYa.
Sep 22, 2010 | Motorola Mobility H371 Bluetooth Headset
Iphone 3G speakerphone and headset volume is too low
Whilst on a call in bluetooth mode change the volume. It needs to be for each different "speaker" you use
Feb 25, 2010 | Apple iPhone 3G
I have a Motorola H681 that used to work fine, now i can still pair with my iPhone, and all buttons seem to work (volume, call button) but there's no audio. During a test call the iphone shows the volume...
I was having the same problem - I ended up just playing with it until it worked again. I found instructions on muting the H700, which is to tap both volume buttons at once. I did that a few times while on a call (I was actually listening to my voicemail), and then I hit the volume up button, and now it works. Not sure if something is loose inside and all I had to to was play around to get it back into place?
Feb 17, 2010 | Motorola Mobility H681 Bluetooth Headset
Jul 27, 2009 | Motorola Mobility H710 Bluetooth Headset
Discovering a Motorola H721 headset on my Iphone
open the boom flip. Press and hold both volume buttons and the call button for more than 10 seconds. The indicator light flashes 3 times and then becomes steady lit. The headset is now in pairing mode.
Nov 26, 2008 | Motorola Cell Phones
Motorola Mobility H371 Bluetooth Headset Logo
24 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
