Question about Horizon Exercise & Fitness
Treadmill stopped working said need lub. Lub bed unit still won't start.
Treadmill, fan and incline not working
jgwhomeequip
  • 1902 Answers
SOURCE: The Incline is stuck at an angle
Check the motor and the gears that run the unit up and down. If is located on the front of the unit under the face plate. make sure everything is power everything. Also check the gears to make sure they did not break and check the tracks to make sure it did not fall off the track causing it to stay up
Posted on Feb 21, 2009
  • 14 Answers
SOURCE: Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
Posted on Apr 29, 2009
  • 19 Answers
SOURCE: Want to lub just purchased '65 Mustang coupe 289 2bbl. Thanks
get the shop manual
Posted on Jun 13, 2009
SOURCE: Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
Posted on Jan 06, 2010
  • 6 Answers
SOURCE: Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
Posted on Mar 25, 2010
Went to go on the treadmill this morning and it's says lub belt? How do you do that?
That is the traction device attached to the drive motor. Not the belt itself. It is a mechanical part that can only be accessed from within the housing and requires a technician to assemble or disassemble the unit.
Apr 16, 2015 | Exercise & Fitness
I have a 2004 s 500 Mercedes Benz. My rear visor it suddenly stopped working. What is the problem?
The slibe on the visor must be dirty try remove dust from the slider and lub it with wd40 or a light lub go in the back get somebody to press the shade boton down and help it to go down with your hand if it move try again untill it down clean it and lub it try lifting it up and down untill it work good
Mar 23, 2015 | Mercedes-Benz Cars & Trucks
Silnik gasnie nieruwna praca silnika
Cze??, Anonymous dodaje dotyczy carbureted r?wnie? modeli wtryskiwanego paliwa oraz Podejrzani to: 1. Mocno roz?adowany lub uszkodzony akumulator, powinien mie? 12,5 V lub lepsze i by? w stanie zda? test obci??enia w razie potrzeby. 2. Nie uda?o Alternator / pr?dnica i lub regulatora napi?cia. 3. Lu?ne lub skorodowane zaciski i czy przewody akumulatora zw?aszcza "negatywne" kabla, poszukaj lu?nych, skorodowanych lub po?amanych z??czy wewn?trz wi?zki przewod?w na "Both" ko?cach. 4. Nie uda?o g??wny wy??cznik lub wy??cznik zap?onu, sprawdzi? pod k?tem lu?nych po??cze? i ci?g?o?ci. 5. Nie uda?o systemu i czy przeka?nik zap?onu, sprawdzi? ci?g?o??. 6. Nie uda?o cewka zap?onowa / modu? elektroniczny. 7. Nieudane CKP, CPS, CMP, Mapa, czujnik TPS lub BAS, skorodowane, lu?ne lub uszkodzone z??cze przewodu wtyk?w / gniazd. 8. przepustnicy kable i pr?dko?? biegu ja?owego lub niew?a?ciwie ustawionymi gor?ca pr?dko?? biegu ja?owego powinno by? 950 RPM do 1000 RPM. 9. powietrza / paliwa ?ruba mieszanin? niew?a?ciwie wyregulowane. 10. Pompa Akcelerator uszkodzony lub nie dzia?a. 11. Woda lub zanieczyszczenia w uk?adzie paliwowym, ga?nik lub filtra. 12. Ograniczone, zablokowany lub zagi?ty przew?d paliwowy. 13. Zbiornik paliwa pusty. 14. Korek gazu nie jest prawid?owo lub odpowietrzania zbiornika paliwa uk?ad odpowietrzania zablokowana. 15. uda?o pomp? paliwa, regulator ci?nienia paliwa, wtryskiwaczy i lub. 16. Przew?d podci?nieniowy od kolektora dolotowego do petcock uszkodzony, p?kni?ty, czy nie pod??czony, ga?nik Przew?d odpowietrzaj?cy pod??czony. 17. Ig?a i siedzisko tkwi zamkni?ty w misce p?ywaka. Aby uzyska? wi?cej informacji o tym problemie i cenne "wolne" do pobrania, kt?re trzeba prosz? klikn?? na poni?sze linki. Powodzenia i mi?ego dnia.
Spanish Hindi --------------- Afrikaans Albanian Amharic Arabic Armenian Azerbaijani Basque Belarusian Bengali Bosnian Bulgarian Burmese Catalan Cebuano Chinese (Simplified) Chinese (Traditional) Corsican Croatian Czech Danish Dutch English Esperanto Estonian Filipino Finnish French Galician Georgian German Greek Gujarati Haitian Creole Hausa Hawaiian Hebrew Hindi Hmong Hungarian Icelandic Igbo Indonesian Irish Italian Japanese Javanese Kannada Kazakh Khmer Korean Kurdish Kyrgyz Lao Latin Latvian Lithuanian Luxembourgish Macedonian Malagasy Malay Malayalam Maltese Maori Marathi Mongolian Nepali Norwegian Nyanja Pashto Persian Polish Portuguese Punjabi Romanian Russian Samoan Scottish Gaelic Serbian Shona Sindhi Sinhala Slovak Slovenian Somali Spanish Sundanese Swahili Swedish Tajik Tamil Telugu Thai Turkish Ukrainian Urdu Uzbek Vietnamese Welsh Western Frisian Xhosa Yiddish Yoruba Zulu Polish Open in Google Translate
New VStar 1100 Owner Shuts down while riding
http://forums.cycleworld.com/archive/index.php/t-164824.html
98 00 Yamaha XV650 Star Service Manual XVS650 Moto Data Project
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
Jun 01, 2014 | 2004 Yamaha V Star Classic
Belts are ok but there is a lot of squeking is there something i can do to stop this
You can start by spraying the belts with Belt-lub which can be purchased at any auto parts store; the lub will also extend the life of the belts. Also check the adjustment to see if the belts need to be tightened.
Mar 17, 2011 | Chevrolet G10 Cars & Trucks
Lub and wheel bearins
there is no need to lube the wheel bearings. yhey are a sealed unit and the grease is sealed in. If you think they are noisy, or are worn out, then you need to replace them. 2008 model, the bearings should last for many years.
Apr 27, 2010 | 2008 Victory Vegas Low
My Singer 221 had a sluggish motor. I lubricated it with genuine Singer motor lub. Both are very old. It gets little use. I brought it to a quilt club meeting to get it going. Sluggish went to a complete...
Do not put anything on the motor at all, it may be the motor brushes need replacing if you can get them, ebay is best, check also the wires underneath the motor if you have the black 221 they are prone to perishing.
Apr 21, 2010 | Sewing Machines
Treadmill stck in upgrade
need to lub it oil whatevever makes it escalade up and down
Jan 24, 2010 | Epic 425 Mx Treadmill EPTL88105 !
My nordic track treadmill won't decline
My wife had the same problem with her treadmill. I turned the beast on it's side, and unscrewed the plastic casing that houses the motor, computer, and all the electronics to the treadmill. I unplugged the incline/decline motor. Then on the bottom of the treadmill the long threaded rod that causes the incline needed to be moved. So I unbolted it from the catch, and manually screwed the rod back in with a wrench. Now the treadmill works fantastically, of course the incline/decline mechanism has been disabled, but I would rather have a treadmill with the incline disabled than have one always on 100% incline. Hope you found this helpful :)
Jan 05, 2010 | NordicTrack Exercise & Fitness
Microwave makes strange sound when turned on
The fan motor either needs maintenance including lub or it need to be replaced.
Jan 01, 2009 | Kenmore Microwave Ovens
Fan Noise
Your fan motor probably needs additional maintenance, in the way of lubrication.
After removing the unit from power, access the Fan blade and spin with finger. If there is any resistance to note then the spindle running through 2 bearing surfaces needs lubrication.
See the other question/answer to fan removal - motor lube.
If you have any sort of humidity to contend with and have a FreshAir model F1 or earlier different type, they seem to have some corrosion problems after a period of a couple years.
It is just a function of the machine/job that necessitates such maintenance.
Jan 12, 2008 | Ecoquest Fresh Air Air Purifier
Exercise & Fitness Logo
18 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
