Question about GE Washing Machines
GE Washer Tub has sunk and is grinding on bottom
posted by golinveaux on May 20, 2009
Looking for info on GE WLRE4500GOWW mode Washing machine. Making very loud grinding noise when drum is moving back and forth. Maybe bad bearing?HELP!!!! Everything works perfectly except that the entire tub and attachments has sunk down enough to grind or rub on the bottom of the washer while agitating. How could a bearing cause this? Is there any way to raise the tub back up about an inch by making an adjustment?
I had the same problem and as near as I can tell, we ran a load the was simply too big and the upper chasis "droooped" just enough from the weight to cause the metal to bow. As a result, the bottom of the tub assembly was rubbing against the lower metal chasis, creating a loud grinding noise. Metal filings indicated the wear point. I took a piece of wood that is about 1"x3x height and wedged it in front and slightly to the left of the motor, running straight, up and down. the board stands straight to take out the bowing- lifting the tub about 1/4" more. This was just enough to provide the clearance needed to prevent grinding. If the vertival board is too long, you won't be able to get the front cover back on.
Posted on Jul 26, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
Sounds like transmission/tub "nut" came loose or if it has the cable/pully balance system (older design) the cable broke.
Posted on May 21, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
WATER COMING OUT FLOOD TUBE ON GE TOP LOAD WASHER MODEL WLRE4500GOWW WHATS WRONG DOES IT ON AGITATE AT HIGHEST WATER LEVEL
Take off the front panel by inserting a putty knife in the clips between the top cover and the front panel. Once the front panel is off you will see a clear box on the side of the tub with a clear tube running from it. Take off the tube and make sure the tube and where it attaches are not clogged with junk. Use a bobby pin or paper clip to clear it out. This is what makes sure the tub fills to the proper level. It is probably over-filling because that tube is clogged. Once the water level is lower, the water won't come down the flood tube.
Jun 13, 2012 | GE Washing Machines
My GE topload washing machine is leaking
Check the hose that connects to the bottom of the tub to the drain hose. Make sure that hose is securely fastened.
May 29, 2012 | GE Washing Machines
GE Profile WPRE6100G tub spins while washing
My parent's Hotpoint did the same thing!! The brake on the bottom of the tub is not engaging! It needs replaced!!
May 15, 2012 | GE Profile WPRE6100G Top Load Washer
Maytag washer model A282 not spinning
very common problem / ck the motor pulley / this is a double v pulley / top runs the main belt to the center and to bottom runs the pump . the lower side of pully has seperated and is running loose . replace it with the new style. it's is a one piece . and replace both belt as a set . this should solve problem/ good luck and thanks for ysing fix ya . ****
May 14, 2012 | Maytag Atlantis MAV6000 Top Load Washer
WCVH6800J1WW GE Washer error codes
need same solution, please post
Mar 03, 2010 | GE Washing Machines
Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Apr 22, 2008 | GE WBSR3140DW Top Load Washer
GE Washer WPSQ4160T
TRY REMOVING FRONT OF WASHER YOU WILL SEE 4 SHOCK LIKE PISTONS TAY GET DRY AND MAKE GRINDING NOISE OR SQUEEKS LUBERCATE ALL REAR HARD TO GET AT MAKE SURE YOU GET TOP AND BOTTOM (RAY)
Dec 07, 2006 | GE WBSE2090A Top Load Washer
Washing Machines Logo
927 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
