Question about Lionel The Polar Express Train Set
Does not chug or smoke when in forward - Lionel The Polar Express Train Set
My Range Rover 2.7 diesel starts but then chugs on a very low idle, no throttle response and black smoke, what could be wrong?
i'd suggest getting the cylinder compressions checked , black smoke indicates burning oil so could be piston rings , also that would explain lack of throttle response and low revs
Feb 23, 2015 | Rover Cars & Trucks
Engine chugs, lots of white smoke
Smell your oil. If it smells gassy, your carb is stuck wide open-i mean the float stuck, allowing gas to run past the valves and into the block, causing the white/blu smoke. Did you fill the oil to the TOP of the dipstick??? Should be at the bottom. Just a couple of scenarios.
May 22, 2013 | Garden
Chugging motor, lots of white smoke.
oil has either run into the muffler or the air filter assembly clean out and good to go.
May 22, 2013 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Gas Blowing Out of Exhaust
Hi Haley
Here are a few suggestions
May 02, 2013 | Cub Cadet Garden
Blowing blue smoke and chugging
Blue smoke usually means your buring oil. I recommend bringing the vehicle to a repair shop and have them determine whether the problem is engine mechanical ,Defective PCV valve, or an over oil filled engine or transmission.
May 11, 2010 | 1994 Toyota Camry
The car is chugging and also blowing out dark smoke
I do not know much about this vehicle but if it is diesel it sounds like you should clean and or replace air filter and or glow plugs or grid heater... if it is a gas vehicle changing the fuel filter and checking spark plug gaps and plugs and wires also the cap and rotor may have where witch will cause intermittent and weak spark so you could be getting to much fuel and running rich. also if it has a catalytic converter you may want to check if it is partially clogged and if it is have it replaced hope this helps good luck
Apr 28, 2010 | 2004 Renault 181
I have a nocking noise from front of my freelander
hi, im not a mechanic but i had similar problem with my freelander and it was the ird unit (or transfer case ). the shims thorned and there was some damage to the gear
Sep 25, 2009 | 2002 Land Rover Freelander
100 series land cruiser is blowing smoke at 2000 rpm and chugging
mine also smokes at 2000rpm and only at 2000rpm when i left my car for a couple of weeks it would not start too bat was good was just yurning over and popping?????????? please helppppp
Jul 13, 2009 | 2004 Toyota Land Cruiser
Replaced a water valve but still makes a chugging sound.
Get scouring pad (green pad) from supermarket and remove cutting try. Use pad and cleaning solution to really scrub the evaporator tray until slippery clean. Use forward to backward strokes, not left to right. Clean all surfaces of freezing tray and that should help.
Apr 11, 2009 | GE Monogram ZDI15C Automatic Icemaker
Black smoke
with only that little bit of info., i'll guess at spark plugs and a mass airflow sensor. is the engine lite on? what color is the smoke? maybe even coolant temp switch.
Nov 27, 2008 | 2003 Jaguar X-Type
Lionel The Polar Express Train Set Logo
43 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
