Question about Samsung Dryers
Where is the thermistor on a samsung dv405
Thermistor location
Illeagle
  • 525 Answers
SOURCE: LG DLE5977 Electric Dryer
Below are some solutions that other customers have cited. The control board seems to have a glitch in it, so I would take it back and get a replacement. New product is covered by a factory warranty or a dealer replacement guarantee. My husband and I just BARELY bought an LG Electric Dryer. I'ts model #DLE2516W. As soon as you hit the power button, "check filter" comes on. The right after that, the error code "Te1" flashes and it does nothing but beep. Clearly, the filter has NOTHING in it because I've never run a load of clothes thru it. When I look in the troubleshooting section of the owners manual, it tells me that this means that the thermistor is open and needs to be replaced. But I'm confused as to why a BRAND NEW dryer already needs a part replaced. Can ANYONE please help me. I have lots of laundry to do. Haha!
Comment by Amanda02, posted on Sep 11, 2007 Well... we took it back to Home Depot and they are replacing it. i was trying to fix it because it takes 3 weeks to get a new one. They don't have any in stock!! And it takes 3 darn weeks to get a new one.
Posted on Jun 11, 2008
docjohn174
  • 943 Answers
SOURCE: location of thermistor installation instructions for thermistor and sensor
hi thanks for the question i think your problem is with the venting make sure the vent is clear to the outside check that thanks the appliance doc
Posted on Sep 25, 2008
SOURCE: trying to locate thermistor whirpool dryer and
Just bought a new thermistor for the Whirlpool Duet dryer and ready to install, does it has any polarity; ie. does it matter which wire goes to which side?
Posted on Jul 16, 2009
canbruce75
  • 1776 Answers
SOURCE: samsung dryer gets a to code
The thermistor or thermal fuse is about an inch long and is inside the rear of the dryer and is usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a blown thermal fuse. Hope this helped and best wishes.
Posted on Sep 03, 2009
SOURCE: GE profile harmony dryer electric won't heat after first load
Did you end up replacing this thermistor? If so did that solve the problem? We are having the same issue and I don't want to waste time and $$.
Posted on Mar 23, 2010
How I fix the Thermistor DA32-00027B
The temp sensor is the white cover where your fan is on the back wall. It has vent slits on it.
Sep 27, 2015 | Samsung Refrigerators
How do I check Thermistor resistance?
You would need to disconnect power to dryer locate thermistor remove one lead from thermistor and check resistance with an ohm meter. there should be a tec sheet somewhere in the dryer and this should tell you what the resistance should be.
Aug 21, 2014 | Samsung DV316LES Electric Dryer
I have a samsung dv337aeg/xaa dryer that does not heat
could be thermistor but also may want to check the heating element, the hi-lo limit thermostat, and see if u are getting full power to the unit as if only getting 120 instead of 240 u have enough to run the motor but not the heater? thermistor located in the housing near the blower, sometimes in the drum or on the door
Jul 27, 2014 | Samsung Dryers
Code e6 samsung B1215J
Hiya,
E6 is listed by Samsung as :- Water temperature rising/falling too quickly. Check thermistor.
The thermistor is the temperature sensor, normally a probe located in the heater.
Unplug the appliance, take the rear panel off and the heater is at the bottom rear of the tub. Check the wiring to it and check the heater for continuity.
Apart from these checks you're left with replacing parts on a "fit and see what happens" basis. I'd try the heater and thermistor first.
Hope this helps.
Thanks
Mar 30, 2014 | Kenmore Elite 45986 Front Load Washer
My dryer shows hE code what does it mean its a samsung
Samsung Dryer Fault Codes ts Thermistor short Check for restricted vent. Replace thermistor to Thermistor open Check for restricted vent Replace Thermistor do Door Open Check connections. Replace door switch. FE Power Source Frequency error Check power source dF Door circuit failure Check wiring to door switch. Replace door switch hE Heater error Restricted vent. Replace thermistor. bE Button Error Check and / or replace PCB od Over dry Sensor Bar open. Adjust time up excessively. Et eeprom failure Replace Eeprom
hE Heater error Restricted vent. Replace thermistor. Heater error
Clean vent and replace thermistor.
Clean all vents from outside all the way to the blwer housing. If you dont get all the lint it will cause this to happen again.
If you need further assistance please feel free to contact.
Jul 24, 2011 | Samsung WF203ANW Front Load Washer
I have a Samsung Gas dryer DV337AGW/XAA. I have an error code that looks like a capital E with the top bar left off and 5. Went through the troubleshooting check list and no fix.
The error code is actually tS which means thermistor short circuit is sensed. The thermistor is located located on the blower housing and it requires the removal of the front panel to access it. Check for clogged lint screen and restricted vent system if the thermistor is found shorted or open then replace it.
Click on the link below on how to remove the front panel and get to the blower housing then locate and replace the thermistor with part number 35001191 or DC32-00007A.
Feel free to update us about the result and/or if you need further advice.
Jun 17, 2011 | Samsung Dryers
Cycle stops at water heating. Water gets too hot and cycle can only be moved on manually. Is this indicative of a faulty thermostat? Where is the thermostat located
Sounds like it.
It is actually called a thermistor, and is located at the end of the heater element.
Which in turn is located at the rear of the washer drum.To gain access, remove lower rear cover of washer, and you will see the element and thermistor there.
To remove the thermistor, slacken the centrt nut securing element, and withdraw the thermistor.
Fit new thermistor, tighten up nut, and that is it.
If problem persists, then it is going to be a faulty pcb.
Feb 13, 2011 | Hotpoint WMA13 Front Load Washer
Samsung washing machine error TE appears part way through wash. Does not appear to be temperature related as it's nearer the end of cycle? Do you know what this error relates to?
thermistor error, so actually it is temperature related. the thermistor is located at the bottom of the tub asm. with the heater element. check wires and replace thermistor. the tech paper in the washer may give the proper ohms to check it with a meter.
May 27, 2008 | Samsung Washing Machines
Dryers Logo
729 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
