Question about Nespresso Romeo E350 Espresso Machine
How to reset nespresso romeo - Nespresso Romeo E350 Espresso Machine
1.My Nespresso Pixie Lights never stop flashing. 2. I also want to reset to factory settings because the cup portions are off. 3. I feel the water temperatures is never hot enough for the coffee
1: Depending on how long you've had your machine, it may need descaling. The machines are preset for hard water - if you're in an area with soft water, try pressing and holding the Lungo button while you turn the machine on. Hold until the lights stop flashing.
2: The Pixie can be reset to factory settings by holding both buttons down before and when you turn the machine on, again until the lights stop flashing - this will reset to factory settings.
3: The temperature is preset to be the optimum temperature for the extraction process. If, after following the above steps, the temp is still too low, call the Nespresso Club and they will advise you.
Hope this is of help to you!
Mar 18, 2015 | Nespresso Coffee Makers & Espresso...
No water flow
i need any vodio abut this machine to see how work
Jul 20, 2014 | Nespresso Romeo E350 Espresso Machine
My romeo nespresso wont leave the descaling mode
"DESCALING" is not a "mode." When the display says "DESCALING," it means that it needs descaling. Follow the directions in your instruction manual.
I need the instructions for descaling the Nespresso Romeo E350 Espresso Machine, I have the descaling solution but not ... Solve It! Solve It! ...
It is fairly complicated, but luckily I found the manual for the device that goes into detail on exactly how to descale it. You want to go to page 8 of the manual. I will provide the manual at the end of my answer here...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
http://www1.nespresso.com/precom/sav/pdf/HD_RO_en.pdf
Thanks
Tim
Oct 13, 2010 | Nespresso Romeo E350 Espresso Machine
We have a Nespresso Citiz C110 which today decided to start having problems. It starts its cycle perfectly but as it is filling the cup the water goes cold and after a few seconds switches the pump off...
Sounds like it needs to be descaled. If this has not been done for a very long time, the scale will have affected the thermoblock and I may not return to full function. I only use Nespresso descale kit (not vinegar).
Jun 21, 2010 | Nespresso Citiz C110
What does F8 mean on display
the capsule dispenser is jammed. shut down the system using the button on the lower right side of the unit. when you turn the unit back on, the system will reset and it will fix itself. (courtesy of my brilliant husband)
Jan 03, 2009 | Nespresso Romeo E350 Espresso Machine
Nespresso Romeo E350 Espresso Machine Logo
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
